Transynd ??
TC_Z
The owner's maunal for our 2007 Winn Voyage 38J gas engine with Allison 6-speed transmission says to use Transynd transmission fluid. I have checked local auto parts and Walmart and don't find it. Has this been replaced by a newer fluid? If so which one?
TC&Z
2007 Winn Voyage 38J, gas 8.1L engine
2018 Jeep Cherokee flat tow
11 REPLIES 11
Charlie_D_
wolfe10 wrote:
Charlie D. wrote:
If your unit came with Transynd it should not require changing unless you have some kind of transmission failure or it becomes contaminated.
And, I would suggest that if this is the OE fluid and therefore at least 12 years old, it is well worth changing (along with the filter).
You are sooooo correct:)
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
edatlanta
Lifetime ATF? Not in my transmission. I change mine and the filter every 25,000 miles. Oil is cheap, transmissions are not.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
TC_Z
For other's benefit, I finally found this at NAPA...
Mobil Delvac 1 Synthetic Automatic Transmission Fluid
TC&Z
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Charlie_D_
If your unit came with Transynd it should not require changing unless you have some kind of transmission failure or it becomes contaminated. You should only have to top it off if you have some loss.
On previous trucks with the Allison 1000 I swapped over to Transynd from Dexron V11. Had to do a double drain and fill then according to the person who helped develop Transynd it should last a life time. Look at the Class A forum and there is a "sticky" where he have answered many questions.
Your owners manual should give you details on when to drain and you may have already reviewed it. I would request a sample bottle from Blackstone and send it in. It would give you details on the condition of your oil.
I did not find a "sticky" after a search but hopefully this will post:
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24963117.cfm
Thank A Veteran
Native Texan
Community Alumni
Not applicable
I buy mine from Detroit Diesel who is usually an Allison repair facility also.
JimR
pigman1
Most truck and bus sales/repair places will have it too. My local Cummins dealer also carries it and I believe I saw it at my local Tractor Supply, but it doesn't show up at their WEB site.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
wolfe10
Or just go to any Allison dealer. Their prices (at least in our area) are not out of line.
They sell it by the quart, gallon and 5 gallon pail. Also have the correct filter for your transmission.
Brett Wolfe
Ex: 1997 Safari 35'
rgatijnet1
Transynd is the fluid recommended by Allison but if you go to the Allison website they will give you a listing of other brands that are also TES-295 approved. As long as you use a transmission fluid that is TES-295 approved you are good to go. DO NOT let some auto parts guy in to telling you that their fluid is just as good and will work. If it does not state that it is TES-295 approved on the label, do not use it. NAPA should have what you need. It is not real cheap but it is what you need.
Allison fluids
ArchHoagland
Transynd is a TES 295 fluid. Any transmission fluid that says it meets TES 295 specifications is good.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Trackrig
Find your local Allison transmission dealer or order it FROM AMAZON.
Bill
