Travato and Adding a Spare Tire
jpittman
I have been wondering about adding a spare tire. I don't want to have a flat where the tire has to be replaced by buying one and have road service come out with it.
I'm thinking about adding this tire carrier so I will always have a spare. Here's the link:
http://www.pickupspecialties.com/Tire_gate/tiregate_hitch_gate.html
I would get the center mount.
Any thoughts about this?
Thanks.
2014 Winnebago Travato, Silver
2003 Jeep TJ, Silver, Locked and Lifted, Rubicon Ready
19 REPLIES 19
wincrasher65
I wouldn't carry a full size spare. Just too big. I've only had a couple flats in my entire driving history.
But if you must, instead of one of those mounts, just get a swing away hitch carrier and put the tire inside that. Use the remaining space for other stuff.
As far as weighing your coach, that's a good idea to see where you are at eventually. But it's pretty silly to even suggest that you are marginal on CCC. You have lot's of capacity left, and certainly enough for a 100 lb wheel.
2016 Winnebago Travato 59K, 2017 Allegro 32SA
Follow my blog: www.wincrasher.blogspot.com
Our Facebook group is: Class B Camper Vans
stan909
Why not get a fold down type like Roadtrek or Pleasure way? I can't remember who has them. They can be used as a grill table for your plug in barbecue.
Handbasket
I'd suggest loading it as for travel (full water, gas, LP, food, etc, & passengers). Take it to a truck scale or other weighing place (I use an Allied Van Lines branch). Get it weighed. Compare to the GVW on the door or glove box sticker. The tire, wheel, and carrier are probably going to weigh in the neighborhood of 100#. Be sure you've got that margin.
Jim, "The doc said that my X-ray showed a broken rib, but not to worry. They'd fixed it with Photoshop."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
jpittman
At the top of that page, there is a video showing the carrier swinging to the right. It may not clear the door 100% but it appears it would clear enough to open the door for access. I will be calling them to make sure it is going to work.
Davydd
How would you open your rear doors?
Davydd
2021 Advanced RV 144 WB 2500 Class B
2015 Advanced RV Ocean One Class B
