ACZL wrote:
This past Sat I heard on local radio station call in program about anything automotive/off road etc where a caller asked about the Triton V-10 in a Class A and the host more/less shot the engine down. Told the caller to shy away from it. I thought that this was a very good engine overall. What's the take on it?
Well First understand I am NOT a Ford fan. have not been for a long time... So I tend to put down Fords.. I will attempt to stick to facts here.
I have heard only two things (Other than the reason I'm not a ford fan) that would turn me off on the Triton V-10 and one that is good.
First the good thing: They still make it. (The competitor Chevy 8.1L Vortec no longer made save as replacement)
Now the negatives. and note only one of these apply
FORD is a "High Reving" engine That means peak HP is a fairly HIGH RPM. The Chevy was a "low Reving" engine. fewer RPM. Fewer RPM means the engine lasts longer (My expierence) generally but not as a rule.
Second there was a period for both engines where they had a problem.
on the chevy Vortec that problem was a clip on a fuel regulator that was made from the wrong metal. about 25 cents parts and 10 minutes labor... The Customer Service manager (national) handed me the clip, and a business card. I attached one to the other. He warned me not to try and replace it myself.. (Alreay had an appointment with a dealer) 2 weeks later I handed the service consultant my keys and the card with part attached.. You can't believe the service I got from that Authorized service center after that :).
On the ford. At the same time. the spark plug holes had like 3 threads and the plugs tended to blow out like a cork from a cork gun. This was a major machining job to fix... Not a "Part of an oil change" grade repair.
HOWEVER that has been fixed.
The only other negative on the Ford is the Transmission.
Even FORD admits that ALLISON makes the best Trannies. and ALLISONS do not fit on the V-10 without an adapt-a-kit.
I won't likely buy another Motor home. If I do it will likely be a Diesel (Detroit if I can get it) but I'd not shy away from the Triton V-10
