Jun-20-2017 06:41 PM
Jun-28-2017 08:18 PM
Jun-28-2017 05:35 AM
Jun-27-2017 06:51 PM
dbtravels2 wrote:
Hi:
Need some help if anyone has encountered the problem of how to control 2
TV's in the RV Living Room. We have a new 2018 Allegro Red with two LG Televisions in the living room. When we try to control one tv both sometime react and sometime do not react the same. We turn one tv to a different channel the other tv may or may not change. Has anyone found an answer to this problem
Jun-27-2017 06:42 PM
rk911 wrote:
how 'bout turning one off and/or getting up and changing channels manually? how is it possible to watch two different programs at the same time in such a confined space?
Jun-27-2017 04:41 PM
Jun-27-2017 01:19 PM
Jun-21-2017 11:52 AM
Jun-21-2017 10:16 AM
Jun-21-2017 09:06 AM
Jun-21-2017 08:48 AM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Jun-21-2017 08:35 AM
Jun-21-2017 08:14 AM
Bruce Brown wrote:mmccray100 wrote:
Every brand of TV uses their own unique codes to control their products.
Your, (and all) TVs use Infra-Red light, so it is "line-of-sight". If you can close a door between the 2 TVs, that would take care of the problem.
I do recall that some brands made a menu option to change the characteristics of one TV to avoid this problem. You might check the owners manual or scroll thru the various menu settings.
Mike
Mike,
In this case it's not exactly line of sight. I was thinking the same thing until I saw how it worked. The front TV reacted exactly as the middle TV, the one with the remote pointed at it. The remote wasn't in any way even remotely (no pun intended) pointed at the front TV.
Jun-21-2017 07:18 AM
Bruce Brown wrote:dougrainer wrote:
Tiffin uses both LG and Panasonic(older Tiffins). There is NO remote programming. There is no fix, but when I test Tiffin systems, I do NOT point the remote anywhere but directly at the TV I am controlling. Even in the LR with the 2 TV's. Doug
When you do that, does it controll both TVs or just the one you're pointing at?
On our friends Allegro when he pointed directly at the bigger mid-mounted TV both TVs reacted. When he pointed directly at the smaller front mounted TV the mid-mounted one also reacted.
Jun-21-2017 06:39 AM
