โJul-13-2014 02:21 AM
โJul-14-2014 08:52 AM
โJul-14-2014 08:11 AM
hipower wrote:
Seems to be human nature to get our exercise jumping to conclusions..on the other hand sometimes it is reading comprehension that is the cause.
โJul-14-2014 08:02 AM
โJul-14-2014 08:01 AM
โJul-14-2014 07:49 AM
โJul-14-2014 06:37 AM
โJul-14-2014 03:50 AM
โJul-14-2014 01:59 AM
kcmoedoe wrote:goufgators wrote:When you posted "Cost: $148. to reset the breaker. Lesson learned!!" with the two exclamation marks, that clearly implies you think the charge was excessive. Personally, if something gets repaired, the faster it is repaired the better. If the thought that you need to spend a certain amount of hours on a repair for it to be worth the cost, I will be swearing off dentists to start with. I will be much happier to pay $500 to have the work done in 10 minutes than pay $200 for it to take 3 hours. There is often value in having it done quickly.goufgators wrote:
Earlier, I posted a problem with the electrical outlets being 'dead' that powers the front and back t.v.'s. I received a number of suggestions and I thought I had followed each in an attempt to resolve the problem. One suggestion was that it might be a tripped ground fault breaker on the inverter. I 'thought' I had checked that and found it not to be tripped. Soooo, I finally took it to CW and turned the problem over to them. Well, the problem was a tripped breaker on the inverter. I obviously did not properly check to see if that was the problem. Cost: $148. to reset the breaker. Lesson learned!! Thanks to all who 'tried' to help me. Next time I'll try to follow suggestions a bit more carefully...
I (OP) didn't mean to suggest that I was concerned about the $148 charge. That charge was primarily for diagnostic service. The problem was corrected and I'm happy. Again, I was not complaining about the charge only trying to provide an update.
โJul-13-2014 02:04 PM
โJul-13-2014 11:09 AM
โJul-13-2014 08:14 AM
โJul-13-2014 06:05 AM
Tom N wrote:
I own a 2005 Itasca Suncruiser.
Your TVs are powered through your inverter.
Check the breaker on you inverter in the cabinet above the passenger seat.
-Tom
โJul-13-2014 05:39 AM
โJul-13-2014 05:36 AM
