value of load lift controllers?
2_Retired
Are air-lift load controllers worth the expense? Do they do enough to create a smoother ride and to stabilize the vehicle? Looking into it but not sure. We have a 2006 Georgie Boy Pursuit, 32' and we almost always add our toad. Thanks.
Two young retirees restless to GO!
Life is too short to wait too long to do all we want to do!!
Go and enjoy!!
5 REPLIES 5
wolfe10
We don't have enough information to give you sage advice.
What chassis?
What are axle weights vs GAWR's.
What are you trying to correct/improve?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
DSDP_Don
I added air bags to rear of my 2004 Fleetwood Terra to raise the back enough to get it up my driveway and into my backyard. I also installed the compressor so I could do the filling from the dash. Since they were there, I used them to set the coach level when loaded. To my surprise, the coach handled much better. Often, just like in DP's, setting the ride height correctly (front to rear level of the coach) makes it handle as designed (correctly).
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Fishbreath
I had air lift bags on my truck with an "in-cab" controller. It made leveling the load a breeze and it made fine-tuning the ride even better.
I felt that the ride was significantly improved.
If you are adding the bags, get the controller!
Bill
timmac
Air bags helped out a smoother ride in my front, 08 Ford Chassis, also gave me more lift in back when bringing my double deck trailer.
bsinmich
I assume you are talking about air bags in addition to your springs. They won't do much for making the ride softer but will help if you are not level. They also will not increase your carrying capacity. I had them on a 35' Pace Arrow in a '96 P-30 chassis and was happy with them for levelling the coach.
1999 Damon Challenger 310 Ford
