โFeb-02-2015 09:13 PM
โFeb-06-2015 06:26 PM
OFDPOS wrote:
I'm going to go check out a 2006 Itasca Cambria 26A? Wednesday it has 14,500 on the OD I could only get a quick look at it last Sat.
But will be able to crawl over under and around it Wed.
Any special areas I need to be concerned about looking at ?
I know with the reg C to look ,touch and feel in every corner especially the overhead cab area.
Being as these don't have the hugh overhead ,still need to look in that area.
Any other typical or otherwise places I need to look at , any particular appliance's to look for or NOT to look for ??
Thanks for any input.
โFeb-06-2015 02:26 PM
โFeb-06-2015 11:00 AM
โFeb-06-2015 10:22 AM
pnichols wrote:You make some good points about having the bed available all the time. I did not even consider in my post, slide-out couch convert-a-beds, murphy beds and other push-button beds. They have their own challenges with being made up......they get torn down, not made up. And they are never readily available.
X100 on what Ron said above re Class C rear corner beds.
I our situation we needed an always-ready bed so the DW could nap or give her bad back a quick rest anytime anywhere on short notice. Our bed had to be "corner" so we could have a short Class C for small campsites anywhere anytime and to also be able to go toadless.
We don't make up the corner bed at all. The mattress has the never-washed, never-removed, vacuumed-only, original Winnebago color matched mattress cover on it. On top of this mattress is a 2 inch foam topper. We use a fitted sheet on only this foam topper and remove/wash/replace the fitted sheet after every trip. We throw a fancy color matched down comforter over the whole thing to help keep it dust-free and "kindof looking organized" between uses. This all works like a champ and helps keep camping life simple.
โFeb-06-2015 09:36 AM
โFeb-06-2015 09:12 AM
โFeb-05-2015 10:35 AM
leeper wrote:akrv wrote:
Take some sheets and make up the rear corner bed.
Good one. This guy knows what he is talking about!
โFeb-05-2015 09:38 AM
โFeb-04-2015 06:01 PM
โFeb-03-2015 05:15 PM
โFeb-03-2015 04:19 PM
โFeb-03-2015 11:48 AM
โFeb-03-2015 10:41 AM
โFeb-03-2015 09:52 AM
