Mar-04-2013 12:28 PM
Feb-22-2014 07:11 PM
jtovosr wrote:
The extentions are not reliable, they will leak sooner or later you can be sure of that. You need a 90 Degree truck tire gauge & throw all the extentions away.
Feb-22-2014 05:51 PM
Mar-08-2013 07:32 AM
homedad wrote:
I had the extensions on my rear duals. I found that if they've been on a long time the valve that the extension is pushing gets stuck open. You need to bite the bullet and let the air flow and deal with the stuck valve. I found that it's fine with the extensions on but if it's flowing just re-seating the valve with a pressure gauge or pointy object re-seats the valve. Then refill the tires. The cheap solution I found was the 135deg stem extension on the outers and just using the braided extension as a temporary extension for checking and filling the inners. You'll need a flashlight to find the valve and need to leave the cap off. I had too much anxiety putting the braided lines on permanently.
Mar-06-2013 03:08 PM
Mar-06-2013 06:55 AM
Hudsoner wrote:willald wrote:
Also don't like the fact that in a way, you're kind of making two tires back into one when you add those things. I know the crossfire is not supposed to allow it to happen, but I have read where in some circumstances, if one tire loses a lot of air suddenly (like in a blowout), the crossfire will allow air to cross over, causing the other tire to go flat as well. Pretty much eliminates one of the big advantages of having duals, if a blowout with one can take the other one with it.
Still a cool idea, though.
Would that situation show up if one would have a pressure monitor attached to the crossfire? If yes, would it show up fast enough that one could react in time?
Mar-05-2013 11:34 AM
Mar-05-2013 08:42 AM
Mar-05-2013 08:22 AM
Hudsoner wrote:
I have the same problems with my rear tires and are contemplating to install the Cross Fire system (http://tinyurl.com/c2fe5k3).
Has anybody any experience with it and can report on it?
Mar-04-2013 08:20 PM
Hudsoner wrote:My son had them on his tractor trailer rig. Junked them!
Mar-04-2013 08:19 PM
Mar-04-2013 07:25 PM
Mar-04-2013 07:06 PM
Mar-04-2013 06:59 PM
Mar-04-2013 06:38 PM
jtovosr wrote:
The extensions are not reliable, they will leak sooner or later you can be sure of that. You need a 90 Degree truck tire gauge & throw all the extensions away.
