i would start by cleaning 'ALL' battery and power cable connections
then pull . check , and re-seat all the main power DC fuses
check voltage at the house batteries, OFF, with drive engine running, and shore power, and finally generator
your converter might be bad
this will show up as good charge from alternator
weak bad charging from gennny and shore
I can explain it to you.
1997 F53 Bounder 36s
