Jul-03-2015 11:41 AM
Jul-04-2015 11:03 AM
Jul-04-2015 08:43 AM
Jul-04-2015 05:38 AM
AZAmmochief wrote:One caution I have not seen yet is that the OP needs to make sure there is water in the heater tank!
TO follow 2Oldman's comment, the water heater is pretty noisy when it's on. I suggest you turn it on, go outside the coach to where the water heater is located, to make sure it's one or not.
If it is on, let it heat for a while, then check to se if you have hot water come out of the pressure relief valve at the hot water heater. If there is, then this is a pluming issue.
If no hot water, this could be the heater's igniter, or fuseable link. Mine went out last years, bought one, installed in about five minutes.
Good luck, hope you find it.
Jul-04-2015 05:19 AM
Jul-04-2015 05:02 AM
Krusty wrote:
Sounds like maybe it is still bypassed?
Jul-03-2015 07:18 PM
Jul-03-2015 03:04 PM
Jul-03-2015 12:35 PM
Krusty wrote:Maybe, but then cold water would be coming out. OP says "nothing".
Jul-03-2015 11:58 AM
Jul-03-2015 11:57 AM
Jul-03-2015 11:51 AM
