water heater problem
ghart204
I have an Atwood water heater on my 2013 Holiday Rambler Vacationer that runs on either gas or electric. The water heats up fine . The only issue that I am having is that once the water has heated up, the gas or electric burner is constantly coming on to heat the water. It is as if the water drops a degree, the burner comes on to heat the water. What might be some possible issues that may cause this to happen. I cannot remember this happening prior to me winterizing the motorhome last fall.
GHart204
9 REPLIES 9
wa8yxm
You found it. the T-Stat shuts the heater off when it's hot and turns it back on when it starts to cool.. Sounds like yours got old and the "Delta" was gone..
Some electronic T-Stats (not compatible with that water heater, or, far as I know, any water heater) have adjustable Delta (The difference between turn on and turn off) but on that one it's factory set... And it appears that old age changed it.
ghart204
Just an update. I replaced the old Tstat and ECO with a new kit. After heating the water up, it seems to be working fine. I don't notice the heater coming on every few minutes. Thanks again for all the great suggestions.
GHart204
ghart204
Thanks for all the suggestions. I ordered the combo pack today. I had a little trouble getting a couple of the wires off. I didn't want to break any. Hopefully the new set will take care of the problem. I will make sure they are both tight against the tank.
GHart204
Old-Biscuit
Your Atwood uses one set of t-stats for both electric and propane operation
They are under the foam cover in outside compartment
Brown wires to/from normal t-stat (preset to OPEN at 140*F)
Red wires to/from ECO (high temp t-stat---preset to OPEN at 180*F)
If t-stats are not held tight against tank wall they can not properly sense the correct temp.
They are held against tank with a plastic washer that presses down a spring and then held down with three small tabs. I hate the design. (Suburban uses a bracket that screws down)
Problem is probably with the normal t-stat not tight against tank.
ghart204
There is no reset buttons on this particular water heater. Thanks for the suggestion.
GHart204
nwrandski
Is there a reset function on the water heater itself. These are usually two buttons on the center of the user panel - next to the burner / high pressure valve. They would be clearly visible after removing the outside cover. I would try this first. My suggestion.
Tim & Cindy
2014 Tiffin Phaeton 40QBH
We very much enjoy our travels and meeting new people
Both still working FT - on the road when we can be
Former Army (7 Years) and Persian Gulf Veteran
See you out there!
enblethen
It may not be the thermostat but the ECO. I would buy the kit with both the ECO and thermostat.
Make sure they are tight against the tank, first.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ghart204
Thanks for the reply. I thought that might be the problem. I will try a replacement.
GHart204
foxtrottwo
Sounds like a bad thermostat.
