Water pressure regulator
Gt327ds
I just purchased a 2012 class a motorhome and was wondering if a 40 psi water regulator is required as in a travel trailer.
19 REPLIES 19
downtheroad
It's not the PRX tubing that fails or leaks...It's almost always a fitting, faucet or valve that lets go.
I'd definitely use a water pressure reg. Ours is adjustable and set at a conservative 4psi...plenty of pressure for our use.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
xctraveler
I have an adjustable regulator that I have set to 60 psi. Modern motorhomes are set up to run 60 for the most part. If you are in doubt, contact the tech department of the mfg or post the details of your coach so someone who has the same brand can be of help. I can speak for Tiffin and Southwind ('04) but have no idea about other manufacturer's specs.
Paul
2012 Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
pianotuna
Nomad III
Nomad III
Hi,
I still use my regulator-and wish to upgrade it.
Regards, Don
WyoTraveler
The newer RVs can take higher pressure with Pex tubing but I still use a 45 lb regulator
donn0128
Required? No.
Suggested? Yes definitely?
