Water tank location
Koli2005
We recently purchased a used 2005 Jayco Greyhawk 27DS Class C RV. Does anyone know the location of the fresh water holding tank?
3 REPLIES 3
j-d
On our Jayco, see Signature, it's UNDER the floor, roughly over the Rear Axle. We have a little access cover on the side of the shower base, and can see it with that off, as well as from under the coach looking up.
tobydad
Most fresh water tanks are under the bed or under a dinette seat. The tank will usually be on the side where the water fill opening is located.
1492
Moderator
Moderator
