weep holes
Bigdog
I had my drivers window pulled a couple of years ago as the double pane needed resealing and was letting water in. After I got it back, there was still water in the sill and they said that my weep holes needed to be reset and said they had done it. The problem has never really stopped and I'm wondering just how you do it yourself, I've had it with that dealer and don't trust them to work on it again. I also found that when they put the window back in, they left a screw out and just filled the hole with caulk and I didn't notice it and now the window has pulled enough away from the coach to cause the caulk to separate and leak. That's taken care of for now, but I still need to get those weep holes lined up.
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
5 REPLIES 5
Bigdog
I talked to the owner one of the shops I go to now and he explained how the weep holes work and showed me a couple of rigs where they were correct. I went home and checked mine and they weren't even close to being correct. He showed me how to cut the felt to expose the holes and I got a couple of done yesterday. I'm working thursday and think I'll take it in to the glass place next to our bus barn and have them see what they can do about it.
I'm also gonna check out the covers from the guy in Bend.
GO COUGARS
dons2346
The National products used the now famous Se-Ge windows
crasster
Pictures could help.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
wolfe10
What brand windows?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
JR45
I have had all my windows resealed by Dave Roots out of Bend, Oregon and that window on mine leaks some water also from the ticket window but that is what the weep holes are for to weep water. Here is the covers if you don't have them helps to keep the wind out.
http://www.rvpartstore.com/products.php?cat=74
Dave Roots also sell (Do it yourself kits)
http://daverootrvglassrepair.com/
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
