Weight on a Class C roof
EdTheEdge
Hello, This is my first post on these forums. I am not new to RVing as I have owned an rv since June 2013. I bought a Thor Chateau 22e new at that time. I go out once a month at least but more often twice a month. I love RVing but even after 4 1/2 years of using "HaRVey" I am still learning things. So here is my first question:
How much weight can a Class C roof withstand? I am 6'4" and weigh 240lbs. I would like to climb up on top to do some maintenance, mostly to wash the roof and clean the fan housings but I fear that I may be too heavy and dont want to damage anything. I'm a very cautious guy so I wanted to ask the experts here before I venture "up there".
TIA,
Ed
HaRVey - 2013 Thor Chateau 22e
20 REPLIES 20
Ralph_Cramden
jrobert01 wrote:
kerrlakeRoo wrote:
EdTheEdge wrote:
kerrlakeRoo wrote:
If what you need to reach cannot be accessed from a ladder on the sides, you can use a small (4'x4') piece of luan or plywood to spread the weight over a larger area, but with the manufacturers constantly looking for ways to build these units cheaper and lighter, I would try to avoid too much time or movement especially on any manufacturers entry level product lines.
I thought of using something to spread the weight around.... I was also trying to avoid purchasing a taller ladder. I have a 12 footer and it's not quite tall enough to reach were I need to reach.
By "not quite" if 8" would make the difference, and you have a solid , flat surface, put a concrete block under each leg.
I even used a picnic table once and put a ladder on it to get on my old "C".
WOW.
WOW Indeed.......
Perhaps a handle change is needed to Edlivinonedge?
Somebody call OSHA LOL.
Too many geezers, self appointed moderators, experts, and disappearing posts for me. Enjoy. How many times can the same thing be rehashed over and over?
jrobert01
WOW.
kerrlakeRoo
EdTheEdge
kerrlakeRoo
memtb
Not to answer “flippantly”....but it depends upon the class c. As with all rv’s, there is quite a range in materials used. We have an older Bigfoot....and the roof is quite rigid. I’m 6’ at 200... I can “barely” detect any roof flex! If you can find any manufacturers specifications, they may offer some guidance as to the limitations.
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
