โSep-16-2021 06:06 PM
โSep-16-2021 08:06 PM
enblethen wrote:
50 amp shore power has two legs of 120 power. Sounds like the adapter is only passing one leg of power which is normally secondary source to power second air and other things like water heater 120 volt element.
Test out put of adapter to both straight parallel blades to single blade
โSep-16-2021 07:43 PM
Bud
USAF Retired
Pace Arrow
โSep-16-2021 07:41 PM
โSep-16-2021 07:14 PM
rlw999 wrote:
You probably just need to bond neutral+ground at the generator to satisfy the EMS. Some generators will have a bonding strap that you can use to do that, but most people buy or build a bonding plug that they plug into one of the generator outlets:
https://www.campingworld.com/portable-generator-bonding-plug-118090.html
Easy โhow toโ make a Bonded Plug for an RV Generator/make EMS system work with generator
โSep-16-2021 07:12 PM
That sounds reasonable but I need a 30 amp plug instead of the 20 amp. I suppose they would they wire up the same?
โSep-16-2021 07:05 PM
โSep-16-2021 06:48 PM
โSep-16-2021 06:32 PM
Tinstar wrote:
It is not a GFI problem and I am reasonably sure it has something to do with the EMS and how it interacts with the generator.
I happen to have an older motorhome without an EMS. I plug it into the generator and everything works normally and everything is powered.
