Feb-24-2021 03:18 PM
May-08-2021 06:04 AM
grldst wrote:Bill.Satellite wrote:
They are new! Where is Toyo manufactured? If it's still Japan, how would you expect to find tires that are a month old? I have not looked into Toyo in many years so if they are now US built (not just distributed) I apologize!
Big TOYO tire plant about 20 miles north of Atlanta. Don't know just what tire sizes are made there but its a big plant.
Tires date stamped 6-9 months old are fine.
May-06-2021 02:25 PM
Apr-14-2021 09:36 AM
Jarlaxle wrote:
Anyone throwing away good tires because they passed some magic age, I'll take them!
Apr-11-2021 09:27 AM
Apr-08-2021 05:49 PM
Feb-27-2021 11:13 AM
Feb-27-2021 05:17 AM
JALLEN4 wrote:
I'll tell you what doesn't make sense...this ridiculous misinformation that keeps getting spread about tire age on forums. If I still owned a tire store instead of being retired I would love it! At the current rate of travel, people on here will be advocating yearly tire replacements sometime in the near future!
The 5-6 year window is a myth to begin with. No less than Michelin, probably the worlds most trusted tire company, says 5-6 years is when tires should have a yearly INSPECTION. They state tires can last ten years but should be inspected for tread separation, bulges, etc annually after five years.
The reason tires deteriorate is because of UV exposure and exposure to the elements while in use. Tires stored in a warehouse certainly are not aging at the same rate as tires traveling down the road. Tires stored on a vehicle parked in a garage are not aging at the same rate as those sitting uncovered in a wide open parking lot.
Tires fail most often because they have been damaged while in use or because they are run at improper air pressures for their use. There is simply no reason to worry about a few months old new tire being installed as the aging process is no where equivalent to one in use. There are a ton of logistical reasons why tires are not immediate production line to mounting on a vehicle. By the same token there are a ton of reasons tire aging is not linear from the production line to the end of usability. People would be much better served to be concerned about tracking tire air pressures, weight load, and annual inspection instead of these amateur "the sky is falling predictions" you find on forums such as these.
Feb-27-2021 04:55 AM
JRscooby wrote:fijidad wrote:Ivylog wrote:
I would settle for tires up to 6 months old as new. Requiring one month, especially on a tire not made in the US is probably impossible. Only RVers are obsessed with the age of tires, especially if you replace at 6-7 years.
Thanks Ivylog. This is the first time I'll be replacing tires on a MH, so appreciate the well-reasoned response.
I think if I had a MH that used 22.5 or 24.5 tires I would talk to a local trucking co, offer to trade my original tires for some that had 50% tread. Tires that are 2 years old, and half tread will age out before wear out, in 4 years instead of 6. Win win
Feb-27-2021 04:53 AM
valhalla360 wrote:CapriRacer wrote:valhalla360 wrote:CapriRacer wrote:
It is a commonly held belief within the tire industry that any tire within 6 years of the manufacture date can be sold as "NEW". I say "belief" because I know of no data that supports (or denies) this.
6 yrs or 6 months.
I seriously doubt you could get a manufacture to go on record saying a 6yr old tire is like new.
Also, are you talking about legally or realistically? Legally, new products that have not been sold before are considered "new". Find a dealer with a 1985 Ford Ranger that's been sitting at the back of the lot never sold, the dealer can legitimately sell it as new but realistically, they aren't going to lie and say it's a 2021 model.
If you read the rest of the post, I said they TESTED the tires and could not find a difference after 3 years. They did not test beyond that because they wanted to set a policy of 3 years and wanted data to back that up. No, they didn't publish the data - it was for internal use.
So what is the 3yr policy they were testing for?
- Can't sell a tire that has set in the warehouse for 3yrs: In that case, it's a flawed test. It should then continue out for somewhere around 8-10yrs as the 3yr mark doesn't test the impact on end of life condition.
- Buyers can use the tires for at least 3 yrs if they buy and mount them immediately after manufacture: Thanks for telling us the obvious.
This story doesn't make sense.
Feb-27-2021 04:27 AM
Feb-26-2021 04:49 AM
6 yrs or 6 months.
Feb-26-2021 04:33 AM
6 yrs or 6 months.
Feb-26-2021 12:03 AM
Feb-25-2021 01:48 PM
