What did you do to your Class A MH today???
Rich_Panganiban
This is always a fun thread to watch, so I thought I would start one here.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
5,655 REPLIES 5,655
Cloud_Dancer
I still have NOT found exactly why the engine in my 7.5 Onan QD is overtemping and causing a computer command to shut itself down.
AND NOW, my 1200LRIM NORCOLD 4-door frige quit working (amonia odor),.....so I have started my search for the best-quality remanufactured COOLING UNIT.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Livin_Good
deaton60 wrote:
Installed new LED replacement in a festoon bulb style for my step lights. New bulb didn't work.
'Discovered that polarity matters on LED's.
Turned it around.
Works good!
Much brighter than the original incandesant bulbs.
You probably reduced your led life considerably due to reverse polarity...
decan9
replaced the OEM steering stabilizer with a Bilstein! next week when I go out, will advise what difference it makes!
Bonnie and me and Casey makes three!
Staying warm in Southern California
FMCA #402157
W9NCR
cmprcountry
Yesterday I picked it up from the shop after getting a new back-up camera. Today I cleaned the refrigerator. Yuck!
Chip
cmprcountry
wolfman01
Finally installed tachometer. These gauges should never be omitted from any vehicle.
2011 Hyundai Accent SE (8k)
1996 Tiffin Allegro Bay 31' ga$$er motorhome (42k)
Bear, my four legged, furry companion.
RVing is an obsession more expensive than drugs. :E
deaton60
Turned it around.
Works good!
roads_to_travel
Had the engine and generator oil and filter changed. Had it lubed.
millerak49
changed the engine oil and filter, now off to fill the propane.
RVRODDER
Fitted new vanity unit and taps,only taken me seven years to get round to it!
Gulfstream Sunvoyager Cummins 5.9BT DP.
rvnub
I pulled all the entertainment system wires out that the previous owner had put in a ran them neater and labled them all so it is much easier to determine which wire goes to what. Getting ready to throw out the old VCR and put in a DVD player along with my Direct TV box from home.
1991 Monaco Crown Royale DP 36ft
6CTA 8.3L Cummins
4 speed Allison with 2 speed rear end
DW=Darlene
Son=Zachary
Boss= Border Collie named Jack
wolfman01
Retucked screen thst started pulling out of channel on screen door.
Buffettphan
Well, not today but in the past few weeks replaced the brakes from the calipers to the pads.
Fixed the levelers,
replaced a few lights and then took a week long trip to Nova Scotia. Oh yeah, replaced the gear shift handle because im a dope......long story.
On our return I cut all the old caulking away from the windows, outside lights etc and replaced with new. Also resealed the roof hoping to solve any leaking that may accur.
So my 1995 Southwind should be in pretty good shape.
Carl
2004 Lance 1010
2005 GMC 2500HD
Bilstine Shocks
Hellwigs
Tork lifts
Stables Loads
Thule duel axle trailer
2012 Harley Davidson Electra Glide Limited
2013 Softail Deluxe
2004 Harley Davidson Sportster 883C
slickest1
Hi all, new to forum, just purchased DP in may. Had the big service done including oil and filters in cummins, allison, onan,new antifreeze,belts,air dryer cartridge. Ouch!! Oh well now i know its good to go. Had first trip, out for three weeks, Alberta to B.C. and back,all was good other than i noticed a cracked exhaust manifold. So back to shop again. Today i installed a new laminate floor in bedroom, plan to do front room when its back from shop. Its a 2000 H R Imperial, 1arge slide, 350 cummins.07 Trail blazer toad on a Blue Ox tow bar, with ready brake, works great.
1998 Holiday Rambler Imperial 40 ft.
Dennis and Marcie and Pup the Jack Russell
iamcanuck45
Pex tubing and fittings are available at Home Depot. They also carry Shark Bite fittings which are compatible with pex. They work great. Was the braided hose the stainless steel kind. If so, there is nothing wrong with the hoses.
'92 Newmar Kountry Aire, 37'.
Andrรฉ and Elizabeth.
First mate: MacDuff (Welsh terrier)
Asst' first mate: Allie (wire-haired fox terrier) rescued
diveman52
Added custom build Stainless steel gutter to my Goof Stream which Goof Stream chose not no install therefor creating a mess of black streaks everywhere.
Any one who thinks Golf Stream builds a quality rig I beg to differ.
40+ Years in Electrical construction.
Retired IBEW Local 595
Every Days Saturday
2008 Newmar Dutch Star 4035
