clotus
Feb 07, 2021Explorer
What does this go to - A/C edition
So I was working on my Coleman Mach15 AC, taping up the divider between the return and the cold air side (whatever that is called). As I was working on the return side (where it sucks the coach air in) I pulled my hand down and my watch band caught a white wire that went up into the unit, pulling it right out. DOH!
The end of this white wire has what appears to be a thermal sensor. I looked up into the AC and it looked like the wire was maybe plugged into an area in the center of the metal fins, so I plugged it into a random hole in the middle area of the metal fins. Ran the air and all seemed to work.
Question, did I plug the white wire with the thermal sensor in the correct spot? I was trying to find it online and could not seem to find it.
