What to and not to do with a slideout.
twainharteartis
Doe's the Motorhome have to be Level when you open the slideout. My Motorhome is a Damon Intruder doe's the slideout stop with and limit switch or a pressure switch?
19 REPLIES 19
twainharteartis
Kiwi_too wrote:
Many do. You need an owners manual. It tells you exavtly ho to deploy your slides. What year. Maybe someone can help with the owners manual.
It's a 1997 Damon Intruder class A I have a owners manual that I downloaded but doesn't say anything about slide outs.
AllegroD
twainharteartis
Thanks I never had a slideout before and I thought that I had heard that the Motorhome needs to be level or it could be damaged. Just want to not do anything that can screw up my equipment.
Mike_M2
My Thor will keep the slide running until i let go of the button. It just won't go any further out when the stops around it hit the outer wall.
Mike M2
Thor Infinity 33SL
donhoward49
My National owners manual says to level first, then slides out..
Sorry, I can not help on the switch.
