Wheel Balancing Weights vs Beads?
precioustime
We have a 28' MH, gas, Ford 450, V-10 engine with 245/70R19.5 tires. The Goodyear Center was not able to balance the 2 front tires with the standard metal weights on the rim due to a lack of a part needed to place the tire on the machine. Instead they added some beads inside the tire and told me many truckers and rv people do the same. Is it the same? Is it better? Will it do the job? Any negative thoughts? I keep it in storage when not traveling but not for too long. Two months at the most.
9 REPLIES 9
Horizon170
Beads are my preference. One time only for the life of the tire. A pint of antifreeze 50/50 mixture will also work in an emergency if you have trouble on the road. Some off road Guys with monster tires use Golf Balls.
Marvin
2010 Coachman Freelander 22TB on a
2008 Sprinter/Freightliner chassis
1995 Geo Tracker (Toad)
Rog___Nan
Had new tires put on at CW in Elkhart (no longer there) probably 10 years ago. Balanced with beads they did what they were supposed to do BUT 1st trip out on a county road front right tire goes down. We had service truck come out- took 2 hours to get there. They put on our spare which luckily is mounted on a rim because by the time we got stopped on a 2 lane road where we could be seen the rim was demolished. We headed for CW headquarters in Kentucky- what a joke did not even want to talk to us. Long story short after Michelin said it was not their problem, Elkhart admitted kid who did the job did not replace the valve stems with new proper ones and a bead got caught causing the tire to go flat slowly. CW finally made everything right and covered our costs and had no more problems for the 7 years we had the tires. New tires are not balanced with beads. This was on a 32' class A which we still own. Luckily we kept the tire and Michelin had us drop it off at a dealer to send back to them for inspection. Can't say beads are bad just make sure everything is done correctly.
Rog & Nan
'96 Cruise Master
32' no slide (love it)
'2010 Vue Saturn Toad
Roadmaster Tow & Brake
Banks Power
pauldub
RLS7201 wrote:
Beads only do static balancing.
Ummm, it's just the opposite. The beads don't do anything when the wheel is static.
RLS7201
Beads only do static balancing. Dynamic balancing, with weights is necessary for a steering axle.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
luvlabs
When they plug up your valve stem...
Good old wheel weights work better, cost less, and are trouble free. Make your tire dealer recommend a place that can balance your wheels.
2017 Winnebago Navion 24V
2014 Tiffin Phaeton 36GH (sold)
2012 Tiffin Allegro 32CA (traded)
2012 Honda Fit
Edd505
The Centramatic's work well, ran them on a class 8 truck. Buddy runs beads in his class A and swears by them, had the conversation just today. He's got beads in front and is getting new rears soon and plans on beading.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
DrewE
Beads work fine. In some ways, they're superior to wheel weights: they can't come loose or fall off, and they will automatically compensate for changes in balance as the tire wears or (to some extent, at least) as dirt or whatever gets stuck to the wheel.
The Cadillac equivalent to beads are Centramatic rings; they're roughly beads in their own separate hoop-shaped tube. I suppose the Centramatics may have some advantages for out-of-round or non-concentric tires (so long as the rings themselves remain concentric). The other obvious advantage to Centramatics, that doesn't apply at all in your case, is that they can be installed without having to dismount the tires.
carringb
Balancing beads work better than weights, as long as the wheels and tires run true. They cannot compensate for a wheel or tire that is not concentric to the hub, and can magnify that issue if it exists.
2014 ORV really big trailer
2015 Ford Focus ST
1492
Moderator
Moderator
Moved from Forum Technical Support
