wheel cut
mikemc53
I have been reading a bit about the front wheel cut (either 45 or 55 degrees?) and was wondering if there is a quick easy way for me to find out what mine is?
2004 Holiday Rambler Vacationer 37PCT with the F53 chassis.
Thoughts?
2021 Gulf Stream Conquest 6250 (Class C)
4 REPLIES 4
wildmanbaker
50 degrees is correct for that era of chassis. F53 MHs with 208" WB, or shorter, will turn sharper than most big Ford and Chevy. pickups.
Wildmanbaker
hammer55
mechanical protractor draw lines on the ground use the protractor to check degree
Corkey05
2018 Chassis Brochure
The chassis design goes back many years, but I doubt the wheel cut has changed. My 05' F53 was 50 degrees.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
SidecarFlip
Measure it. Wheel cut on MH chassis is adjustable (most times) by setting the stop bolts on the front axle. Just so long as there is no tire contact with the frame or wheel wells, all is good.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
