wheel valve extenders
kiloo9
I got some of the valve extenders starting to leak, the seal between the extender and valve stem are deteriorated, drying up. Has anybody ever replace the seals, would like to replace all of them. The extenders are Wheel Master # 92-9243
Have a great day
Josรฉ
"Freedom is not Free"
Ask a Veteran
7 REPLIES 7
427435
Replace them with these.
http://www.ryderfleetproducts.com/ryder/af/ryder/core/content/product/srm/oid/125662/pn/Flexible-Val...
Even if they break, the valve in your tire stays intact.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
teddodd
J&R wrote:
Just take an extension to auto parts store and get O rings that fit.
the best that I have ever had is www.duallyvalve.com.
J_R2
Ron & Joanne 06 Revolution LE 40E
JR45
I got a set of these from Camping World works great so I can install my TST
http://www.campingworld.com/shopping/item/straight-valve-extenders-4-/31693
Had 3" extensions, just to short.
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
Fishinghat
I previously used extenders until one leaked and caused a tire to go flat while parked. It could have caused some major damage, but I caught it before driving off.
The commercial tire place recommended I not use the extenders saying they leak too frequently to be reliable. Apparently, the extenders rub on the outside tire wheel where they go thru the hole in the wheel and that's where they fail.
Instead, get a commercial type pressure gauge that allows you to reach in and check or fill a tire without using an extender. They are very inexpensive.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
kalynzoo
If you lose pressure and then lose the tire it will probably cost a bunch more than new extenders. My one blowout years ago took out some fiberglass and a couple of wire harnesses. Could have been much worse.
Get new shiny ones.
JMHO
FIRE_UP
Hey Josรฉ,
How about that, I remembered how to make your "รฉ". Pretty cool huh? Anyway, nope, I personally have never heard of anyone replacing just the little seals inside those extenders. I don't know if they can be replaced but, it may be worth looking into. I suppose you could dissect one of them and see what the seal looks like and then, head down to your local AutoZone or whatever's close and see if they have anything that comes close.
How's the ticker? Getting your exercise? Blanca doing fine?
Scott
Scott and Karla
SDFD RETIRED
KI60ND
