Chowan wrote:
That is a great suggestion, but here is my problem. I do not own the RV. I have all the gross rated numbers, but I don't have the real weight of the coach. How can one find out how much a coach weighs. And thus make some important calculations on what size toad I need to buy and how much stuff I can load and still be with in the rated limits. I don't want to buy something only to realize what I want to do with it cannot be done. Know what I mean. Thanks
The only real way, is to post the exact model of coach, you're interested in and wait for a knowledgeable like owner to chime in.
For instance, this recent new to us purchase had plenty of CCC posted in the closet with it's specs. so, I never gave it another thought and I was right, except for one small problem, as this rating wasn't evenly distributed. As it turned out and after moving in, we found that we were over on the rear by 160lbs, even though we were more that a ton to the good on the front. No biggie, I guess and even though I'm most sure all our tanks weren't full.
Now here's the real ringer and I've since found out on the American Coach forums that many of the larger coaches with a tag axle are grossly overloaded on the front with some spending thousands for a heavier axle. Can't sue FW as they were in chapter 7 for most of this and you can't blame Spartan for instance, as they didn't build the house on top.
As for GCWR, I usually just subtract the difference from the GVWR and assume the the rig will be loaded to the max. Even at this, you can be overweight with the toad, IMO, as long as the frame and tow equipment is inspected for strength and durability. I say this because it's all calculated for the steepest and longest grades, so it's never noticed for the most part. When it is noticed on those long 6%k or more grades, it's usually the transmission that suffers and there's a lot you can do with that, if it should become a constant problem.
