Where to plug in converter
rware
I have a 2009 Holiday Rambler Admiral 30SFS made by Monaco.
In the rear power hookup compartment there is a converter screwed to the back wall with a small 2 foot power cord and a standard 3 prong 110V connector. Can someone with a similar coach tell me where the converter is plugged into?
The long story. When I got the coach I had solar panels and an inverter added. The inverter also powers the coach battery so the converter was no longer needed. The solar installer said leave it there unplugged, if you ever remove the inverter you can plug the converter back in. Well now I am having problems with my inverter tripping, until I can get that sorted out I wanted to turn of the inverter and plug in the converter so that at least my house battery bank got charged at night.
Here is the problem, I can't find where to plug the inverter in. I have crawled around that compartment with a flash light over and over again, there is no 110V outlet. It is driving me nuts, the converter used to work but where was it plugged in. It had to be within a very short distance of the converter given the power cord length. I could run a 110V line down from the coach, it wouldn't be too hard, but there has to be a 110V outlet there somewhere!!! I am going nuts looking for that thing. :h
Thanks,
Martin
9 REPLIES 9
time2roll
rware wrote:
I wondered if the installer had removed the outlet but couldn't think of any reason why he would. Now I get it, that is how he wired the inverter into the house system. Mystery solved ๐Ÿ™‚
Seems odd. Does inverter output backfeed into this connection?
Or does the outlet feed the inverter to pass through power to a sub panel when plugged in?
Or something else?
Is it an inverter/charger combo? (no converter needed)
wny_pat1
rware wrote:
Thanks for all the replies.
No outlets in the transfer switches unfortunately.
The inverter is all hard wired. The converter is still connected to the battery. So I think I will just run a new AC line to give me somewhere to plug the converter in. As both the inverter and converter are connected to the battery I just need to make sure I only run one at a time.
The converter converts 120 vac from your shore power to 12 vdc to operate the coach lights, etc. It has to be plugged in somewhere close by to do this. It should also connect to your battery to charge it. The inverter gets it 12 vdc operating power from the battery to convert it into 120 vac to operate what ever is connected to it. Not knowing how he set things up, it is going to be difficult to sort out what you want done, and you may not be able to just unplug one, and plug in the other. Hopefully your installer gave you a schematic for how he hooked things up. If he didn't and you don't know your way around electric tracing, you might be best to go back to him and get things sorted out, and this time, get him to make you a schematic!!!
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
rware
Martin
wa8yxm
Inverters come in a couple flavors.. USUALLY if an inverter has a Plug (As opposed to just outlets) it is a combination unit, Converter and inverter in one.
So you may not need teh other converter
Now.. if both have 15 amp plugs (The flat blades look like this || )
THen you can use a cube tap
If they have 20 amp plugs ( -- | )
You got a problem
jhilley
I agree with Diplomat Don. The installer must have used the receptacle feed to take the AC back to the distribution panel. It could be a little work to go back. Running a new feed for the converter would probably be the most expedient thing to do. You will have to move the DC cables from the inverter/charger back to the converter.
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
DSDP_Don
Martin.....The inverter has to connect to 110 volt power so it can be powered up (pass thru) when the coach is connected to shore power. My guess is whoever installed the inverter, took the plug (outlet) that use to power the converter, cut it off and hardwired the electrical into the inverter.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
KD4UPL
Is it possible that the inverter installer removed the outlet to make room for something else? Is there an outlet built into the back of your power center somehow?
time2roll
Some transfer switches have a converter outlet for use with an inverter.
Just a longshot.
John_Wayne
Are the wires from the converter to the battery still contacted? If so just unplug the inverter and plug in the converter. My converter just plugs into a 120 outlet.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
