Who knows about FCCC "MMDC" and its issues?
FIRE_UP
Gents,
I've searched and read many issues regarding the old "VDC" units and the newer MMDC units. I'm thinking I may have developed an MMDC issue. Here's the scenario. We're presently on vacation and all has been going well. We were on the freeway, I-10E, just outside of Lordsburg NM when all of a sudden, the speedo started dropping. I had the cruise set to 60. The speedo started dropping, stumbled a bit, then fell to zero.
The rig was corresponding to that too. In other words, the cruise had been shut down. Along with that, the tach went to zero, the oil pressure, water temp, turbo boost, and voltage gauges, all died. I think the air pressure gauges for both front and rear are still operative but, I can't remember (we're camped in Silver City NM right now). Another problem, and a serious one, the exhaust brake QUIT!
And, on my annunciator panel, the "ABS" has lit up, and "Check info center" is also lit up. When I look at the Medallion Info Center, it's reading "No data from Trans ECM and NO DATA from Engine ECM for 25 seconds", and is flashing that over and over.
Now, with all this going on, here's the deal. The engine is still running like a top. The trans is still shifting and operating flawlessly. All the lights, turn signals, brake lights and most other normal electrical stuff is still working just fine. And, I also have what's known as the "Trip-Tek" computer on board too. And, to those of you that don't know what that is, or don't have it, it's a system by which additional information, engine stats, trip odometer(s), maintenance items and more, are displayed on the monitor of the back up camera.
Well, since I lost all important gauges, I hit the Trip-Tek and all the engine stats, oil pressure, engine temp, trans temp, etc. are still just fine and operating just fine. My fuel gauge is working just fine.
Well, I pulled off the road, into town, and got lunch. Then we pulled the rig onto a side street and I called Freightliner help. They started to direct me to the MMDC 10-pin plug. They say those pins can get damaged due to the weight of the harness(s) in that area that tugging away at the plug. My phone was acting up too so I was in an out of the conversation with the Freightliner tech so, I thanked him for his time and went out and pulled that 10 pin plug and looked at it.
It looked just fine to me. Now, I also talked with my son, who works as an RV tech in San Diego and he has replaced many MMDCs due to faulty soldering on and in the pc board inside them. That's the same issues the older VDC units were having. What's up with these boys that do these boards? Anyway, to those who've had issues with the later MMDC units, did you have the same or close to the same symptoms? Is there a way to tell if the MMDC is actually bad without taking a chance on $400 or $500 worth of experimenting?
As stated, my speedo quit and so did my odometer. Now, to me, that's kind borderline "illegal" isn't it? I mean, heck you could drive that thing for another 100K miles and then get it fixed and, sell it as a "lesser mileage" vehicle". But, that's beside the points here. I sure could use some help here.
Scott
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
22 REPLIES 22
cbeierl
jerichorick wrote:
I understand the frustration you are going through. My 2005 Winnebago Vectra is at freightliner at this time for two issues, one being the odometer and the other being the failure of the coolant expansion tank.
Here is what I understand about this problem. The computer that monitors and all of the chassis functions is the ECM and it is fully programmable by Freightliner. One of the functions of this unit is to send a heartbeat signal to the MMDC. This in turn converts it's information to a signal that the dash readout (odometer) can display. The MMDC is not programmable according to Freightliner.
In my case, the MMDC failed. The replacement is displaying zeros on the dash from the factory. Freightliner is standing firm that it can not be calibrated to the known 53,913.0 miles stored in the ECM.
I am negotiating a trade. The dealer will not take my coach in trade if the odometer is not reading mileage correctly in the odometer.
I found bligidy.com in the Dallas, TX area. This is where the coach is in for repair. He claims to be one of three people qualified and experienced in calibrating the MMDC. I am hoping he will work on my coach today. I will post the results when I have it.
A instrument repair shop in Ft Myers, where the trade is located, says he can pump a signal into the MMDC to change the mileage to the correct value. This method is crude because it will take about a week to reach the 53,000+ goal. My dealer is satisfied with this and is willing to take my Vectra in trade.
As you can see, having the odometer set incorrectly can cost the owner hundreds of thousands of dollars at trade-in time. I feel Freightliner is very wrong for not doing what is common in the auto resale industry by not providing accuracy in the odometer reading when serviced.
I hope this information is helpful to you.
I know that Freightliner can preset the mileage in the MMDC in some fashion, because they did it on my coach when it was new. It had mileage from the factory, but there was an MMDC problem found before I picked the coach up and the MMDC was replaced by Freightliner and the mileage was reset to match what it was. My memory is that the local Freightliner service center had to provide the mileage to somebody else (Freightliner?) so that the MMDC could be set correctly before they received it.
Chris Beierl
2005 Winnebago Vectra 36RD
jerichorick
FIRE_UP
Thanks for posting the cure. I think you're like a bulldog when you've got a problem to solve. I enjoy reading your posts.
Fred
Fred,
I chuckled on that one. "Bulldog" huh? That's funny. As I've stated many time before, I do almost all my own work for many reasons. Probably the same ones most of you do it for. One, to save money, two, to "hopefully" do the job correct, three, to learn more about my (our) rig, and four, if I post here about what I've done, (right or wrong), maybe some one can benefit from my trials and tribulations.
dougmac,
Yes Sir, the J1939 is quite a system. But, in all reality, it's actually very simple to me. It's two wires and two resistors. It simply transports info, to and from, all concerned parties that are attached to it. Even though I've only done one in my life time, to me, it's the same thing as a "Conference call". All parties get to speak, at the same time. They get to voice their opinions, ask questions and get results, all on two wires. Until two weeks ago, I had no idea it, the J1939, existed.
Since then, I've learned quite a bit about it and, there's also two more data links in that system. One is the 1587 and the other is the 339D. As I understand the principle operations of the 1587, it's simply a data link, a very slow speed one at that, around 96 BIT, between the Engine ECM and the Trans ECM. That's why the engine and transmission could "talk" with each other while the J1939 system was down.
As for the 339D system, as far as I can tell, it's a small data link that's intended for only two components. One, the MMDC and the other, the Information Center. That data link is what is used to display info on the information center. This stuff is cool.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
dougmac
Good job!! Those j1939 problems are not for the faint of heart! I am glad it all worked out for you.
fcooper
Fred
Fred & Vicki
St. Augustine, Florida
FIRE_UP
Well Gang,
To anyone who cares, the problem has been fixed. A very long story short. It was exactly what I thought it was. A broken wire/bad contact pin, in one of the three wires that make up the J1939 Data link. It was the green one. A very strange situation if I must say so. After lots of investigation, unplugging connectors, checking resistance, continuity and general condition of all the connectors involved in the J1939 data link.
Well, with a bit of help, the engine was running and I was at the helm watching the gauges. My son was under the coach, tweaking and wiggling wires. Eventually he found the problem area. I shut down the engine and got under there with him. He pointed out the general spot. I got under there the next day and went to work on trying to find and pinpoint the exact spot. It was very tough. I eventually narrowed it down to a connector or, an inch or two in either direction of it. I ended up braking part of the connector so, I finished the job.
What I found was, a broken green wire right where it enters the back side of one of the pins. The Yellow and black one was perfect. I ruled out the thought about stress on the wire(s). If that was the case, then why didn't the yellow and black ones break also???? So, what I figured was the original installer just goofed up when stripping the green wire and cut it too deep and cut off most of the strands of the copper wire too. It took 49,000 miles to vibrate/break off the rest.
So, I cut off the entire connector and installed a Weather Pack one and all is back to normal. All my gauges work as they are supposed to. So, I hope this never happens to anyone of you, it's a severe pain in the a$$ hunt down and trace the broken section.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
FIRE_UP
dougmac,
Well Sir, so far, I've done some tests that have indicated that the terminating resistors, each 120 ohms, are both intact and in good shape. But, based on the test procedures, when I test the correct pins in the diagnostic ports, on each end of the coach, I'm getting a "119-120" ohm reading on each end. According to the results I'm getting, the J1939 is OPEN. The readings I'm supposed to get from the two pins is 60 ohms. So, now it's simply going to be the painstaking, methodical tracing of the J1939 data link, all the way down the frame etc. The MMDC, and it's connections, pin testing etc. are all just fine.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
dougmac
FIRE UP wrote:
Dougmac,
Sorry for the late reply. The last couple of days we've been on the road, on the way home, and camped where there was no I-net. So, we're home now. My rig is in it's parking spot, under the cover, on concrete and, ready to be analyzed.
This is going to be all new to me. I've not had to do any type of searching for problems like this before. There's only about a thousand miles of wiring in that coach and, almost all of it inside that PIA corrugated plastic loom. Nice for protection and segregation but, a pain when trying to trace wiring. Now, you say the "engine and trans are communicating fine"? With what?? The medallion info center that receives all that type of stuff still says "Engine ECM and Trans ECM no data. But, maybe you mean they're talking to each other and working good together 'cause the rig is still running down the road fine, just no data being sent to the speedo, tach and other gauges.
Scott
That is exactly what I am saying... The Engine and transmission wouldn't be happy if they weren't able to communicate with each other. Because it seems to run fine and the transmission is working like it should, I am assuming that they are communicating.
FIRE_UP
Dougmac,
Scott
Scott and Karla
SDFD RETIRED
KI60ND
dougmac
FIRE UP wrote:
Dougmac,
Well Sir, let me put it to you this way. While the tech was looking and looking for the two resistors, AM I'M PAYING FOR HIS TIME, I thought I'd do something that makes sense, CALL FREIGHTLINER CUSTOMER SERVICE!!!! So, I called, told them my vin, and my issues and they told me right where the two resistors are. The first, as stated, is just down a few inches from the rear diagnostic port.
And the man on the phone also told me that the other one was "In the MMDC". I confirmed what he said and, he said yep, it's inside the MMDC.
That phone call took all of two and a half minutes. Well, I jumped out of the car and ran (fast walk) over to the tech. I told him what I found out. He said he'd found the one at the rear but was not aware of the other one being "inside" the MMDC. So, he ran some sort of checks and said that yep, it's not answering his probe tests the way it should so, they ordered up, a new MMDC from Memphis. It was air freighted in and, the installed it at about 3:00 today.
Well, guess what, that did not cure my issues. And, talking with some of the other techs there at the Freightliner Service Center, and they said that they've NEVER HEARD OF THE END RESISTOR BEING inside the MMDC.
So, now I'm stuck. I told the service center that since the new MMDC did not work, I was not going to pay for it, and, they wanted me to stay one more night in this rat hole of El Paso and I made the decision right then and said "nope" "Wrap it up" I'm leaving with it still malfunctioning.
That Freightliner Service Center "On the Border Freightliner" is by far, the worst operating repair center I've ever had to deal with. While there, the wife and I talked with other RV owners and, several over the road truck drivers and they all agreed, it's one of the worst Freightliner Service Centers in the U.S. Absolute horrible people skills/communication skills, phenomenally slow in every phase of an encounter with a customer, from the start, through the analyzation process, repair process and realllllllllly slow in wrapping up all the paper work.
What a nightmare. We will never, ever go anywhere near that town again.
Anyway, so, after that much rambling, I'm here, at a much nicer camp ground, in Las Cruses NM and, it's quieter, cleaner, and way more civilized. But, I'm still broke. No speedo, no tach, no water, oil, volt and turbo boost gauges. No cruise control and or exhaust brake. The coach is operating just fine. I will do some attempting to check connections etc. while we're out traveling. So, we'll see. Thanks again.
Scott
From my experience,your problem doesn't sound like a problem with the resistors. Generally the network will operate with one of the resistors unplugged.
Obviously the network is able to function because your transmission and engine seem to be communicating fine. From what I am gathering it seems like the MMDC is the only device that is having trouble communicating. I would be looking at the leg of the network that goes to the MMDC.
BTW... I may have been right there with them digging around for that resistor. I would have never thought of them placing it inside of another component.
FIRE_UP
Dougmac,
Scott
Scott and Karla
SDFD RETIRED
KI60ND
dougmac
FIRE UP wrote:
One of the things I learned yesterday was, there's two resistors in the J1939 data link. One is accessed just down line from the rear diagnostic port, just above the radiator. The other, is located INSIDE the MMDC.
Now if this isn't one of the most asinine things done in auto technology, I don't know what is. You see, that little, "$.50" resistor, is INSIDE a $400.00 computer. So, when that little fifty cent resistor goes bad, you get to spend $400.00 and, pay to have it replaced when, I can have that MMDC out of my coach in right at 2 minutes.
So they put one of the "end of line" resistors inside of a component? Wow, that is one that I haven't seen. I agree.. that is dumb!
FIRE_UP
"If you could identify the pins on the connector that the wires go to you can see if you have a good connection to the data link by checking the resistance between the two pins. If it is around 60 ohms, you have a good connection to the data link. You want to be sure the other controllers connected to the data link are shut down when you are testing."
Dougmac,
I most certainly appreciate your assisting me with this issue and "coaching" me on some test procedures. If I were at home, I'd have dove into this with both feet. That way, if I screwed something up, we wouldn't be stuck some place in "Nowheresville" and then have to get tow, and all that stuff.
In the time we've owned this coach, I've taken the time to read and learn about the innerds of this beast as much as possible. Some stuff is easy to comprehend. Some, you almost have to be a "Suma com laud" from MIT to grasp the concepts.
Computers have done well in making todays autos a more better, safer and more efficient machine but, they've also made them SERIOUSLY MORE COMPLICATED in terms of searching out problems.
But, since I was/and still am, somewhat limited in diagnostic capabilities, I/we the DW and I, are going to take the shaft when it gets replaced today. So, live and learn. And some people wonder why I still change my own oil.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
dougmac
FIRE UP wrote:
dougmac,
On the back of my MMDC, the controller for the annunciator panel and all the gauges is a 24 pin connector and a 10 pin connector. Among all the wires that are entering the back of the plug to the 24 pin connector are two that appear to be the J1939 wires. They are green and yellow and are twisted. I got that far. But, from there, they travel deep inside that loom and go to who knows where.
If I were at home, in my own environment, and didn't have WIND BLOWING THE PAINT OFF THE RIG as it's almost been doing for the past three to four days, I'd do more to take this project on. But, being on the road, the wife and the dog with me, in not so good camp spots, Wind blowing everything, not having anywhere near all my tools, I'm really out of my element here.
This will be the FIRST TIME I've EVER had to PAY for someone to fix MY RV!!!! Boy, does that suck! I've got an appointment with Freightliner tomorrow morning at 08:00 to get this thing in there and see what they can come up with.
Scott
