It is most likely your 94 model RV is not equipped with a modern smart mode converter/charger unit. Your converter/charger may a unit that is only producing 13.6VDC when you are plugged into shore power or generator and this is the DC voltage that is used to keep your RV batteries charged.
13.6VDC is known to boil out battery fluids if left ON for long periods of times. One must start a battery maintenance program to at a minimum start checking the battery fluids and not ever let them get drained below the battery core tops.
When the fluids get below the cores inside the batteries then this allows the cores to start building up crud and eventually creates a short circuit. When that happens it is usually game over for the batteries...
Unless you just have lots of money and like to keep buying batteries everytime you take your old rig out for trips this is going to continue to happen.
The batteries is the center function of the 12 Power Distribution Center and one needs to learn all they can on how the battery system works and what to watch for to maintain the great performance. You just can't install new batteries and thats all you do from then on...
I measure my battery terminals with a hand held multimeter every time I walk around the unit. When a battery is fully charged it will read 12.6-7 Volts DC just sitting there. When I get back from a camping trip I like to read the battery terminals when I shut down everything and then the next morning Ilike to read the terminals again after it sits over night. If they are down to 12.2 or lower after just sitting there in place for 8-10 hours then this is indeed a red flag.
A multimeter can be picked up at WALMART-LOWES- or any number of auto parts stores for less than $20. Harbor Freight used to give you one free when you made purchases there...
Then I will engage shore power or generator and read the battery terminals again with my multimeter and it should now be reading 13.6VDC or what ever mode my converter/charger unit is in at the the time. This tells me my charging is working fine and the battery cable path and connections is all connected properly with no tripped DC circuit breaker if equipped or blown in line fuses. When looking around the battery terminals it will be very noticeable to see when they have been boiling out fluids... When they boiling out is actually occurring you may smell something like rotten eggs and your battery case case may also be warm to hot.
I check my battery fluids about every two weeks now but never find them low any more since I upgraded my converter/charger unit to a modern three stage smart mode charging unit. This almost takes care of your batteries for you...
My trailer came setup with four 85AH 12V Interstate batteries in 2008 and I lost one right away due to my inferior single mode converter/charger unit. Boiled out the fluids in one and I didn't catch it. Then this battery ended up with a shorted cell inside it and would not hold a charge. I have been using the remaining three 85AH 12V Batteries every since doing just great. These batteries are just failing and need replaced... Pretty good for being eight years old I would say...
Just things I do here in the battery department on a regular basis with my pride and joy Camper unit.
I usually don't respond to CLASS A forums comments as all of this is way above my $$$ class. But you did ask "Why did my coach batteries die?"
Hope some of the comments help...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
