Oct-18-2013 05:12 PM
Oct-23-2013 10:02 PM
Oct-23-2013 05:50 PM
Oct-23-2013 12:41 PM
msmith1199 wrote:
... The photo being talked about is the wrong way to set up a motorhome...
Oct-23-2013 12:37 PM
Oct-23-2013 12:16 PM
CT_WANDERER wrote:
I know when I was working we had mobile cranes. We had to have all wheels of the ground with the jack holding it up, to have a level and stable platform. Why would it be different with the MH, if all the wheels are off the ground and level? I like it when the MH is level and very stable, no rocking when moving around inside. I keep the lift to a minimum to get to this point. My only concern is when the MH gets too high off the ground. Just a different view.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Oct-23-2013 11:57 AM
Oct-23-2013 11:06 AM
Lobstah wrote:msmith1199 wrote:Lobstah wrote:
Is the owner causing damage to his motorhome?...no
Is the owner causing damage to your motorhome?...no.
And the issue is?
Jim
The issue is this is a forum to discuss issues related to motorhomes and to help educate people about motorhomes and their use. The photo being talked about is the wrong way to set up a motorhome so it is a very good discussion to have. And as to your question about is he damaging his motorhome? The answer is maybe. Jacks are designed for a straight up and down load, not a side load. When you start lifting tires off the ground, especially all four, you increase the potential for side load damage.
I am really not trying to be argumentative here, so please understand my question.
The OP stated the site is nearly level. If all 6 wheels are in the air, where is the side load coming from? On an very unlevel site, I understand your point.
He's on a level site, and he raised his coach higher than some folks THINK is necessary.
Jim
Oct-23-2013 11:04 AM
And the issue is?
Jim
Jim
Oct-23-2013 10:34 AM
And the issue is?
Jim
Oct-23-2013 09:27 AM
Bud
USAF Retired
Pace Arrow
Oct-23-2013 08:58 AM
And the issue is?
Jim
Oct-23-2013 02:14 AM
Oct-22-2013 10:05 PM
And the issue is?
Jim
Oct-22-2013 07:05 PM
