Will my pipes freeze?
darin338
Tonight where I'm at the temperature will be 27 degrees outside from 2am to 8am. My motorhome is in storage, no heat force just outside.
Do you think 27 degrees for 6 hours is long enough to freeze my pipes.
Thanks!
18 REPLIES 18
bsinmich
You should know by now how you made out. What happened.
1999 Damon Challenger 310 Ford
RayChez
You better drain the water or put some kind of heater in your coach and open all the drawers so that the heat can work its way to where the pipes are. Yes 27 degrees is cold enough to do some damage to your pipes.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Executive45
Yep!...how long does it take your fridge to make ice cubes..:h...Dennis
MountainAir05
If you have water in them good chance. Just blow out with air and you will be fine.
