Will this battery minder work for me?
Pexring
My coach has 4 6-volt deep cycle batteries. Will this 15W solar powered SCC015 batterMINDer be worthy of keeping the batteries up to snuff? My coach sits outside 365 days a year so might as well make the sun do some of the work.
Here is a link to the manufacturer's website (if it doesn't get removed).
***Link Removed***
10 REPLIES 10
Sam_Spade
Pexring wrote:
it sounds like the 15W panel would struggle to do so.
And if there is a small parasitic load and/or as the batteries age a bit it will struggle just to KEEP the charge that they already have.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Pexring
Dennis M M wrote:
That will work fine to maintain, not charge, but it can be done a lot cheaper!
I used this solar panel
and a Battery Tender controller along with 20 feet of wire and a couple of quick disconnects.
I have four 950 amp cold crank batteries in the truck. So far it works fine to maintain them, after about a month it still has not charged them up enough for a green light on the controller, but last time I hooked it up the batts were showing 12.5 volts and when I disconnected to use the truck it was at 12.9 volts, so the solar charger is doing the trick.
I've used a 120 volt Battery Tender to maintain the batts for years, but next winter the truck will be sitting in the AZ sun with no electrical available, so I wanted to put this charger together.
That's only a 6W solar panel, about what my coach came equipped with to trickle-charge the chassis batteries. Was hoping the 15W panel I linked too could charge the house batteries but from what others posted it sounds like the 15W panel would struggle to do so.
gbopp
Pexring wrote:
Let's try this.
batteryminders.com/12-volt-solar-charger-maintainer-desulfator-panel-scc-015
CLICKY
Dennis_M_M
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
2oldman
It might work if the batteries are disconnected from any load.
Sam_Spade
By itself....NO.
That is about 1 amp total capacity.
Divided among 4 batteries, that would be .25 amps each.
You might get by if they are AGM.
Not even close if they are conventional flooded.
Pexring
Let's try this.
2oldman
If you post it sans the url tags it will stay. Go figure.
gbopp
Yes, your link was removed because you are a new member. I'm not sure how many posts you need until you can put a link in your post.
Just post the address. We'll make a link for you.
And, welcome to the forum.
Pexring
Why do my links get removed? Is it a newby thing? What is the waiting time before I can use new links?
