Window Pull
bluwtr49
One of my window pulle...don't know if that is the correct term or not, came off the sliding pane in one of my opera windows and I'm trying to figure out how to fix it.
The pull is an extruded piece of Al with the latch. There appears to be two pieces of a rubberized double back adhesive tape that attaches it to the glass. The window opens vertically so there is a fair amount of pressure on the pull when it's being opened and when it's resting on the catch.
Any thoughts about where to get that tape would be appreciated. Naturally the glass doesn't not seem to be removable with pulling the whole window out and I'd like to avoid that if possible.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
2 REPLIES 2
fcooper
When I repaired my fogged window, I discarded the double sided tape and glued the handle with trim back onto the window using the same sealant used between the two panes of glass, which was C.R. LAURENCE 877 CRL Super Spacer Sealant. It has held up for 2 years now. The C.R. LAURENCE 877 CRL Super Spacer Sealant is available on Amazon and Ebay.
Fred
Fred & Vicki
St. Augustine, Florida
MountainAir05
They have double side tape at Lowes, other home centers. That is what I used when mine came loose. They also have glass glue.
