windshield coming lose
Bossandbabe
I have a split windshield and the padsenger side is popping lose at upper right corner. Then extends downward. It was that way when we bought it, had it put back in place (didn't see what they did), later it cracked. Got worse, replaced it. Now its separating again. Any advise?
Dana and Judy
2000 Tiffin Allegro Zephyr
2012 Jeep Wrangler Unlimited Sahara
2 REPLIES 2
clhamon
We had the same issue. It came out, cracked and we had it replaced. Glass guy warned that once it has happened it will continue to happen unless we take precautions. Always try to make left turns when possible instead of right turns because by making wider turns around corners and into driveways it helps keep the front of the coach from flexing. Also try to lower and retract levelers together as much as possible to eliminate as much twisting of the frame and body as possible. Instead of extending levelers a longer distance use blocks under the tires to gain closer to level in those really unlevel areas.
Hope this helps but I am right there with you and in the same boat!
Frenchie & Kat
2005 Country Coach
2007 Harley Ultra Custom
2016 Jeep Grand Cherokee
Big_Katuna
Since your so close, I would take it to the Tiffin factory.
My Kharma ran over my Dogma.
