Windshield whistling noise wont go away
ricelake922
Hello. I have a 1996 Monaco Dynasty and three years ago I had both windows at front replaced. Last year a whistling noise started and the man who put in the windows came and stretched the black fitting around the windows so the noise stopped. No noise all last summer until October when I took the coach out for last trip. The man who put in the windows is coming back to fix. Anyone have any ideas about how to fix this permanently? Thank you in advance.
12 REPLIES 12
wa8yxm
The gaskets seem to shrink (the rubber gasket around the glass) and sometimes the windshield can move a bit (mine did) since it just sits in the gasket... One company the bottom channel on the windshield is a "U"" or "J" shaped so it holds the bottom better, Others it's L shaped and the windshield may tend to move down a bit exposing the upper corners or the lower corners
I wound up straping mine in with cargo straps (USE caution do not scratch the glass with teh ratchet) and sealing the openings with sealant.
Big_Katuna
I use the wide blue painters tape as it comes off easier.
My Kharma ran over my Dogma.
Johno02
Get a roll of black electrical tape, and start by putting it whereever you think the sound is coming from. May be hard to find. Older Hurricanes had a noise which got to be called the "Hurricane Whistle" that very few ever found. In most cases, it was air going in the front grill. Some got relief by adding a screen. Just to say, get a positive location before doing anything expensive.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
rgatijnet1
Of course you also want to make sure that you don't have the volume turned up on your rear view camera. This can give a sound in the front of your coach that you can't figure out.
Big_Katuna
I get a howl/whistle from the left front corner on my 05 Fleetwood Expedition. It gets worse when there is a quatering headwind from the passenger side.
Doesnt do it under 60. Gets louder with speed.
A semi truck in front of me creates turbulence which disrupts it.
I have covered the weep holes, taped off gaps around the mirror, taped off windshield gaps, hood gaps.
No success.
Next Im going to fasten a tennis ball or softball to a 4' sick and hold it out the window and move it around while driving to see if I can break up the airflow and pinpoint the area.
Its frustrating.
ricelake922
Thank to all and I will cover the weep holes with good tape.
Executive45
Start with the EASY stuff FIRST. As rgatijnet1 said, your rig has weep holes at the bottom of all your SIDE windows. Normally they have small covers on those holes. They are there to drain any water that comes off the windows. You have Se-Gi windows on your rig. Over time those covers lose their grip and fly off. The small holes then cause a whistling sound...think blowing over the top of a soda bottle. A small piece of tape over the holes will tell you if that's your problem. A very cheap fix....Dennis
Se-Gi Weep Hole Covers
gbopp
ricelake922 wrote:
I plan on keeping the RV till one of us dies....the RV or me.
Then fix it right. Call some local RV dealers and see who they recommend for windshield/window repairs. Or contact a couple glass shops in your area and see if they are familiar with RV's.
JMO
rgatijnet1
Just to throw out another possibility, if the drain holes on the passenger or drivers side windows have lost their covers, it will cause a whistling noise. A piece of tape over each one will rule them out as a possible cause.
ricelake922
RoyB
This reminds me of a story about this guy that was having problems getting his truck windshield fixed right to keep from leaking. Took it back two or three times and nothing got fixed.
Then the last time he took in they said they couldn't do anything else...
So he goes outside and finds a hugh piece of concrete and smashes it into the windshield.
It got fixed after that.... A bit drastic I reckon but Insurance sure doesn't like you driving with a cracked windshield
I guess this is a true story...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
gbopp
Several years ago the windshield gaskets on our 96 Southwind were pulling away from the body.
I had the windshields reset at a glass shop. They told me the factory did not use enough sealant when they were installed. The techs removed the windshields, cleaned and reinstalled the original gaskets using plenty of sealant.
I still have the Southwind and have had no problems with the gaskets leaking or shrinking.
You probably need to have your guy remove the windows or windshields and reinstall using enough sealant.
Just stretching them is a temporary fix.
I paid $300 to have the windshields reset, which I thought was very reasonable for the amount of work involved.
How long are you going to keep your Monaco? 😉
