Jun-06-2014 10:30 AM
Jun-10-2014 11:41 AM
Rerler32 wrote:I found a 3 foot white hose at WalMart.
Yep, That what it's for. I connected water to the outside and hose inside and it works fine. Now I just need a short hose for the inside to connect to a sprayer. I'm not sure why they just didn't install a tank spray system but I guess this works fine too.
Jun-09-2014 09:12 AM
Jun-08-2014 12:43 PM
Jun-07-2014 08:15 AM
mikeh449 wrote:Never seen a tank flush on the inside. :? I guess it could be an after market add on.
black tank flush
Jun-06-2014 05:21 PM
Jun-06-2014 01:56 PM
Rerler32 wrote:That would be my guess, hook a hose to the outside one, & a hose to the bathroom one, then turn the outside one on & see if anything comes out of the bathroom one. Be sure to direct the inner hose somewhere safe, like into the toilet.
I have a 2001 Winnebago Minnie 29' and have a water connection in the waste bay that I can't figure out what it's for. There is a separate city water and gravity fill outside of this cabinet. When I connect a hose to it I don't hear anything filling. I tried with the pump both on and off with same results. I looked for a valve that might need to be switched and found one under the sink in the bathroom but when switched seems to just drain the water on the ground near the rear tire below. If fallowed the hose from the outside connection and it goes up inside the rv in the bathroom under the sink and then to the side but can't track it further. I'm thinking it may go to this hose connection that is in the bathroom "in picture" but not sure what it is for. Do I connect a tank srayer to this and go in toilet to clean? There is no mention of this in the manual at all so may have been a add on. If anyone has a setup like this that can give me a hint on how to use it would be great. Thanks. Posting a few pics.
https://www.dropbox.com/s/02qiko1f1ddigam/2014-06-06%2011.59.47.jpg
https://www.dropbox.com/s/s4pqrcif4b57eei/2014-06-06%2012.02.00.jpg
