Winter: Storage or Usage
PartyOf_Five
One of the benefits of a C is that you can drive it like a car during the winter to turn over the fuel, fluids, tires, etc. This year we're storing in a parking lot, and so will have to move our's every so often - or not. Is it better to cover the tires, dashboard, etc. or to leave those exposed so the RV can be driven around when there's no snow on the ground? I've already winterized the water supply, covered exterior vents, etc. so that's not a concern but I've been reading about cold starts, and started wondering if it isn't better to leave it alone for 4-5 (very long) months and just run the generator periodically. We're already 18 years old, so I can't imagine there's too much damage left for me to do either way...
Thanks!
PartyOf5 appreciating our Creator thru the created. 5 yrsL 50k, 49 states & 9 provinces.
May you find Peace in all you endeavor.
7 REPLIES 7
Rick_Jay
IF you live in an area where they use salt on the roads, make sure the roads are dry before you take it out. In fact, it's best to wait for a mild spell, after it's rained (to wash away a lot of the salt), then go out when the roads are dry. Otherwise the salt on the undercarriage will quickly start turning all of the steel to a nice rust color.
I sometimes take our Class A out during the winter for a drive, but ONLY if I can find a day which meets the above conditions....AND I'm not working! LOL And yes, WITH the generator running & the heat strips on too!
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
Lwiddis
Good point, dedmiston!
dedmiston
Moderator
Moderator
Lwiddis wrote:
Just run the generator periodically? If running the generator is to top off the house batteries, there are easier ways...small solar system on the roof keeps my batteries charged when Winnie is covered up. 25 watt panel with a weatherproof WindyNation controller.
If he has a generator, he has to run it 30-60 minutes per month under a load to maintain it.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Lwiddis
Just run the generator periodically? If running the generator is to top off the house batteries, there are easier ways...small solar system on the roof keeps my batteries charged when Winnie is covered up. 25 watt panel with a weatherproof WindyNation controller. And you bet my tires are covered in storage...takes two minutes to remove the covers and five minutes to reinstall.
lhenry8113
I am in So. Calif. with our Class C in our driveway. Have tires/wheels covered and windshield covered as well as passenger/drivers side windows covered. Today it is about 75 but the last month has been in the 80's-90's. Bought the covers through Amazon. Particularly like the windshield cover because of the additional privacy it offers while in campgrounds.
2017 Chev/CLass C Forest River Forester 2251 SLE
A Positive Attitude May Not Solve All Your Problems But It Will Annoy Enough People To Make It Worth The Effort.
H Albright
DutchmenSport
I would think if you covered anything, it would help block the suns UV rays and that is never a bad thing. I cover my tires when home, even if we are home for a couple days and then take off again. It's not any problem covering and uncovering the tires with properly sized tire covers.
About your dash? I see folks in parking lots putting sun screens across their windshields in the cars all the time, mostly in the Summer, to help keep the sun from heating up the inside so much. They just fold up when done and tossed in the back seat.
If not in use, covering is always beneficial against UV rays. The only exception may be covering the entire camper and then you plan to use it again soon. Covering with an RV cover and removing it repeatedly over the winter is a real pain in the neck. If the camper sits though, covering is beneficial.
donn0128
Short drives can be more desteuctive that leaving it sit. If you do drive it, plan on at least an hour at freeway speeds. Short drives can leave a lot of unburned fuel, lots of moisture etc sitting getting fluids gunked up.
