You can easily make your own antifreeze kit. Just get a length of hose and the appropriate size connector. Locate the inlet on the pump, disconnect the hose from the tank, put your new hose on and the other end in the af jug, then turn on the pump. Replace everything when done.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
