Winterizing our generator
Uncle_Dan
I will be leaving my Tioga in Michigan this winter and will not have anyone to run my generator for 5 months. How can I best winterize my generator which runs on the motorhomes regular gas.
Uncle Dan, Shirley and Dusty our cat
12 REPLIES 12
jerseyjim
RAMBLEOnNW: I accessed that link. Thanks. And....what was there? Some said add the Sta-bil first, then fill the tank. Others...add the stabil after the tank is full. Still others said it doesn't matter...the sta-bil will get mixed no matter what.
I use a full bottle into my 75 gallon FULL gas tank. Drive 18 miles to the house. It mixes. Has to. It don't float.
Thanks for an interesting coupla' minits.
jimmy
RambleOnNW
jerseyjim wrote:
RAMBLEOnNW : Where did you get that tidbit of information from? You're saying that Sta-bil, for instance, floats on top of the gas? How does it not mix?
Interesting.
JerseyJim: How is the small quantity of Stabil or Seafoam going to diffuse into the much larger quantity of gas otherwise and how long will it take such that the treated gas will get into the gen carb? In my case I use 22 oz of Stabil for 55 gallons of gas. That is 22 oz in ~7000 oz of gas or a 320:1 volume difference.
I generally keep the gas treated such that each time I run the gen it gets treated gas unless we are on a trip and running multiple tanks of gas. In that case I'll add the 22 oz of Stabil when we get back.
Other folks generally agree.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3231892/Fuel_stabilizer_before_or_afte
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
jerseyjim
Interesting.
Matt_Colie
Dan,
You don't say where in Michigan, but have you noticed a few boats? Take a hint there.
Fog the engines. This will coat the corrosion prone surfaces with oil. The main engine is electronic fuel injection, but it will still benefit from Sta-Bil or Seafoam in the fuel. When you get it put to bed, then fog the generator. When you choke it with fog or shut it down, then look for a fastener in the bottom of the carburetor and loosen that. let it drip until it stops and then take it back tight. That should adequately drain the carburetor for the winter.
Have the fuel tanks as full as is practical to minimize the tank "breathing" that will invite moist air into the tanks.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
RambleOnNW
Add the Seafoam or Stabil to the tank, then fill with gas, then run the generator.
It does no good to add the fuel treatment to the top of a filled tank, it will not be mixed into the gas.
Uncle_Dan
Thanks to all of you for your advice. Appreciated.
gbopp
In addition to the above recommendations, I would also change the oil and filter.
jerseyjim
When returning from our final trip before winter, (we don't snowbird every year) I fill the gas tank,("regular" grade, as usual) then add an entire bottle of "Sta-bil". Start the motor, start the generator, and drive the 18 miles from the gas station to the house. That gives the "Sta-bil" time to get to everywhere in the fuel system including the generator. Easy.
Having no one to start the motorhome or the generator during the winter, I would suggest you remove the batteries. They might get damaged (or damage the motorhome battery trays)...and most likely would need replacement in the spring. Just my 2 cents.
Strabo
pianotuna wrote:
Hi,
Fill with premium gas, use the rv and generator, fill again with premium gas. Add sea foam. Run generator. fill to the brim with premium gas.
Yes sir, that's it.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
AJBert
Or........
After treating the tank with SeaFoam/Sta-Bil/your choice of stabilizer, run through the genny for a little while and then cut off the fuel and let the genny run until it dies. This will get the fuel out of the carb, thus preventing any varnish build up. After cool down, pull the spark plug(s) and spray with fogging oil.
Very common practice with outboard motors.
pianotuna
Nomad III
Nomad III
Hi,
Regards, Don
rskrbina
Have fresh gas in the tank and add "Seafoam" to the tank. Run the generator with 1/2 load for two hours.
Rudy, Jenny and Garrett
2014 Thor.. Four Winds 35SK Super C..F-550..6.7 Diesel
CRV, F-150 & Wrangler Sahara Toads..TST Tire monitor
