Wiper size - Advice please
Kidoo
Hi, I want to replace the wipers on the Cayman 2003, double windshield.
The wipers that are installed are 24 inch and seems to be a bit small. I wonder if I install a bigger wiper, like 28 inch would end at the bottom of the windshield.
Thanks
Monaco Cayman 34 2003, Cummins 300HP
Bigfoot 2008, 10.4, F350, 2006, Diesel 6.0, Black, 4x4, long box, Air lift, Rancho 9000, Rear sway bar.
10 REPLIES 10
WILDEBILL308
Stop and think if you went from 24 to 28 that means they are only 2 in longer on each end.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
Kidoo
I just bought two at Costco, 26 inch, just a bit longer, so this should do it, they where the same price, no mater the size.
Thanks for your inputs.
Gjac
I had 22 in blades on it when I bought the MH I replaced them with 24 in and then 26 or 28 in blades. The longer blades work good when raining but if I use them to just clean the windshield they do not return to the original position with the window dry because of more surface drag on the blade. Not a big problem to me but it might bother some.
Tinstar
Just measure at about 3 places and see if there is room. I put longer ones on mine.
:CNever pass up a chance to go somewhere:C
DSDP_Don
Wiper blades can be expensive and they may have changed the size. You just need to be careful they don't hit each other when they sweep.
Costco sells Goodyear wiper blades for a fantastic price. I think about $8.00. The largest comes in 26" which should work well for you.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
blawless
We have a 2005 Coachmen Aurora with the split windshield. It calls for 32" Wiper Blades. I have 28" on it now, just can't find any 32" in our regular haunts. It sure is nice having a full view through the windshield. The Coachmen has the wipers mounted from the top of the windshield and has no problems moving the 32's back and forth.
B.
Retired and enjoying it!
2005 Coachmen Aurora 3380 MBS Class A F53 V10 Banks Power System.
2014 Jeep Compass Toad
2001 Fleetwood Prowler 255B 5th wheel
2003 F150 King Ranch Supercrew 4X4
RV_CONUS
If you are not the original owner, they may have gone to a smaller blade that was available at the time.
My blades OEM were 32", but, not going to pay $40+ for wipers. I went to a more common 28" blade, easy to find.
I purchase the 28" locally wherever we are. If I happen to find a larger blade available at a reasonable "to Me" cost, I'd use it. I have replaced the wipers 2 times since 2006.
2006 Allegro Open Roads 34WA
2015 GMC Terrain
2009 Blue OX Aventa LX
2009 Brake Buddy Classic
Kidoo
As long as the motor does not suffer. If they are too long, there could be less pressure on the windshield, especially on highway with a heavy rain?
teddychamp
I have a Fleetwood Bounder 39r and it uses 26 inch blades that seems to perfect.
Fleetwood Bounder 39R 330hp Cummins Turbo Diesel
Freightliner Chasis
Ford Escape Limited - on ACME Towdolly
Fiverwheel
It would seem to be a matter of measuring the 26" wiper at its arc closest to the edge of the frame to see how much room is left at the top and bottom. I increased the length of the wipers on my Cayman but it has a siingle piece windshield.
2006 34' Monaco Cayman
