โApr-19-2016 09:14 AM
โApr-20-2016 09:04 AM
โApr-19-2016 11:27 AM
โApr-19-2016 10:10 AM
kuziwk wrote:
Hey guys I have come across 4 gel batteries for free that I would like to use. I have a compartment which also holds my pd9260 charger converter connected to a single lead acid house battery in the engine bay.
I have crimped terminals with 4 ft of 10 awg wire to the positive post of two of the gel batteries with a 30 amp in line fuse and a 30 amp toggle switch straight to the dc fuse board through a 80 amp main fuse. I am grounding the batteries at the frame with 8 awg.
Additionally I will be hooking up the two other gel batteries in a rear hitch mounted toolbox due to the weight concerns in the compartment holding the other two with the converter (under the bed). I'm using 6 awg for the power straight to the positive post of the two batteries under the bed to connect to the batteries in the toolbox, length is around 7ft. I will be grounding these to the frame utilizing the same ground point as the two batteries under the bed...so running a 6 awg from the negative posts to the frame.
My interconnects between the two batteries placed next to each other under the bed will be 10 awg and the two batteries in the toolbox will be interconnected with 10 awg aswell. Is there an issue using 10awg? I plan to disconnect the batteries via the switch when driving or plugged into 120 and charging the gels separately with my solar panel and a dedicated 12 amp gel charger.
I figure 10 awg is fine since I don't intend to either charge or draw more than 30 amps. On a side note how fast can gel batteries be discharged? Faster than they can be charged? Each battery can not be charged faster than 5 amps each.
Just for the record my draw is as follows
-250 watt infinity basslink subwoofer (will draw from lead acid house battery under the hood but likely will only draw 100 watts unless it's really.turmed up)
-fridge (propane)
-lights
-heater fan, bathroom fan, range fan
-potentially small portable 150 watt inverter for a small tv or phone and laptop charging.
The reason why I have different guage is what I have lying around
One more question, my dc fuse board is directly connected to a 80 amp fuse and holder with a 2" peice of 4 awg, while I have all my connections with lugs that are a bit crowded on the other end of the 80 amp fuse. Can I install a 150amp terminal strip and connect this to then 80 amp fuse with 4 awg?, or will this increase resitance. Again the only reason is because then fuse holder and 80 amp fuse are getting. Crowded with lugs.
Thanks guys
Porsche or Country Coach!
