โFeb-13-2014 05:11 PM
When the generator is operating, a 12 volt signal is applied to the generator input. This inhibits the isolator from operating. This is to prevent the generator/converter combination from supplying power to the chassis.
functions which might over-load the converter or the generator circuit breaker.
โApr-16-2014 06:09 PM
โFeb-20-2014 03:39 AM
โFeb-19-2014 05:01 PM
โFeb-19-2014 04:25 PM
OnaQuest wrote:dougrainer wrote:OnaQuest wrote:
There is ONE on-line site that has all the info we have discussed here, available in PDF format. Every Intellitec product and every manual.
WELL???????? WHERE IS IT?????????????? DOUG
I wouldn't want you to have to waste your valuable time searching for manuals for anyone. Why don't you just tell me what manuals you need and I will link you to them.:)
โFeb-19-2014 01:19 PM
โFeb-17-2014 08:23 AM
NOT online as they used to be. I have had numerous talks with Intellitec over the years about why they dropped the original website and put up the current pitiful website. I have an extensive library from over the years at work for Intellitec, I do NOT have time to request individual manuals and such from my Intellitec suppliers. BIG WASTE of my time. They dropped the ball big time on their website. Having a GOOD functional website keeps people from calling them for help and manuals. Doug
โFeb-17-2014 08:11 AM
โFeb-16-2014 02:22 PM
โFeb-16-2014 10:35 AM
fcooper wrote:
My coach does not charge the chassis batteries when on shore power, it just charges the house batteries.
I'm considering replacing the currently installed Intelletic Relay Delay (charges house batteries when alternator output is sensed) with the Bi-Directional Isolator Relay diesel 2 (BIRD).
Fred
โFeb-16-2014 06:01 AM
OnaQuest wrote:
Doug, (Dougrainer) ALL Intellitec products (and their manuals and brochures), including the 839 are still available from authorized Intellitec sources. I have access to them all. Believe me, the 839 is still very much in production.
โFeb-15-2014 06:05 PM
โFeb-15-2014 02:55 PM
OnaQuest wrote:dougrainer wrote:OnaQuest wrote:dougrainer wrote:dougrainer wrote:
At the BIRD there should be a GEN spade with a wire. DISCONNECT that GEN wire and the BIRD should allow bi directional charging as long as the Converter(Inverter/Charger) supply voltage is OVER 13.2 volts. Remember, BI directional when on Shore/Gen ONLY happens when the House charging system supplies over that 13.2 volts. Once the Charging goes to float(usually this is less than 13.1), the BIRD drops out the charge to the chassis side batteries. Doug
I doublechecked my files and went to Intellitec. They offer NO BIRD that has a Genset setting that I can find. IF your Monaco has such a system that is designed and installed by Monaco. I do not remember a charge system that had the Genset disengage the BI charging just on Genset. We sold and I seviced Monaco's from 1998 till they went under in 2008/09. They DID have a feature (optional on the models from Cayman/Diplomat/Knight and down the cost scale/standard on the higher lines) on the large main fuse board up front in the storage, there was an empty area in the center with a multi prong plug where you could buy from Monaco and install the Bi directional module that would charge the chassis when 120 voltage was available. Now, Monaco sent out a TSB over 10 years ago and this may be what you have---When the original wiring was done, IF you have an Inverter/Charger or a converter that had the bulk charge adapter, when the chassis engine was ON and the genset was ON and the Inverter/Charger went to BULK charge (over 14.1 volts) this caused the ALT light on the dash to come on. This was because the fault for the chassis Alt as set at 14.1 volts or over. The solution was to install a relay that was connected to the genset Hourmeter 12 volt positive thru a bosch relay that anytime the chassis engine was ON and the Genset was ON at the same time, the chassis Alternator did not charge the coach batteries, since the Inverter/Charger would be charging them. Once the Genset was turned off the bosch relay closed to allow the chassis Alt would charge the coach batteries. Doug
Doug, everything you say here is true except the statements in red. Intellitec makes the model 839 BIRD. The 839 has the gen lockout feature designed to prevent the interference you mention above. Monaco does not make a BIRD device.
The OP has a 2000 model The 839 was NOT available back then. MY post was for HIS model. Intellitec obviously developed the 839 after 2007/08. The Bosch relay system I mentioned was DESIGNED by Monaco for the problem I outlined. IF they had the 839 back then, that is what we would have installed. If you read the 839 instructions, it specifically states that the Gen spade and design is exactly for the ATL fail light when Gen and Engine running at the same time. So, that is how the OEM's have addressed the Alt fail light problem. This problem can happen on Roadmaster/Ford/Frtliner chassis systems. Workhorse never had the problem. Doug
You are changing what you said. You said Intellitec does not offer a BIRD with the gen set lockout, not that they didn't in the past. You are right that the 839 was not available in 2000 but I'm pretty sure the 366 (it's predecessor) was, and it had the lockout.
โFeb-15-2014 10:01 AM
โFeb-14-2014 05:10 PM
