โMar-05-2016 09:25 PM
โMar-09-2016 09:55 AM
booty51 wrote:
You were able to drive mo ho with auto park light on.Usually that means that the auto park break is engaged. And with the break being engaged you should not have been able to move mo ho.
โMar-09-2016 09:38 AM
โMar-09-2016 08:27 AM
lonfu wrote:
yes, the glue will have an "unlocker". could be carb cleaner, laquar thinner(like car paint) or just regular paint thinner. Some times a heat gun will soften the glue to make the old panel come off easier, but you still have to clean the surface completely. I don't recommend a propane torch as they can be a bit tricky, and burn the entire coach down. It is tough to get off. You will need to make up some upright braces to hold the new panels in place. Usually a board that is braced against the opposite wall or some other part of the coach.
โMar-09-2016 08:05 AM
โMar-09-2016 07:31 AM
lonfu wrote:
I used the 3/8 inch ply, but check your roof material to be sure it is wide enough to cover the extra height, 1/8 inch at each side. I use PL-400 subfloor adhesive on any thing that I'm screwing down. If I clamp then I use titebond 3. both should be available at Home Depot. the reason I use the PL-400 is that it is pretty waterproof. I used it one time to seal my brass boat plug base into my boat 6 years later it is still holding water and I haven't sunk yet!!!!
Moho construction rule, glue AND screw!!!!
โMar-09-2016 06:28 AM
โMar-09-2016 06:19 AM
โMar-09-2016 05:40 AM
โMar-09-2016 05:23 AM
โMar-09-2016 04:49 AM
โMar-09-2016 04:32 AM
B.B.Upch wrote:lonfu wrote:
Rubber roof, yes replace it, but if you can afford it, then replace it with a single piece aluminum roof. It is easier than it sounds. The hardest part is getting the aluminum up on top of the coach and remembering to put on sunscreen while you are installing it. I always coat my roofs with white roof coating to reflect the suns rays.
You will have build any replacement cabinets, I can show you how to make the doors. Make cabinet bases the same way as the ones you pulled out. Buy an air nailer, titebond 3, and a bunch of clamps. I like 22 or 23 gauge nailers as they don't show, but an 18 will work just fine. You can use paneling or MDF and paint it. Many choices...... Wife and I prefer greys, blacks and reds vs the yellows and greens of many of the older coach styles. So, we remodeled... If you have questions or would like some pix private message me.
What glue do I use to put the wood roof & walls on? Seems like everything is glued on lol
Not sure how to private message. This forum is a little different then the one I'm use to.
Thanks I have a buddy that offered to help with the cabinets (he builds custom cabinets for a living) so that's good.
If I do this I am looking at going with a 3/8 plywood b grade for the roof that way it has a smooth side. They are about $17 a sheet at homedepot & going with the 1/4 luan side walls they are about $12 a sheet. I could go with 1/4 on the roof since that's what's on there now but I think the 3/8 plywood could make it stronger.
What do yall think?
โMar-09-2016 04:23 AM
โMar-09-2016 12:26 AM
โMar-08-2016 03:59 PM
