Zone 2 Air Conditioner is not working
jannlanz
Hello,
I have a Dometic 3109228.001 5 Button Comfort Control Center that runs our heat and air conditioner. Zone 1 is working, but Zone 2 only gives a blank screen and won't allow me to choose any settings. Does anyone know what the problem could be? Thank you so much.
10 REPLIES 10
Snomas
I had the same problem and to correct I replaced the J11 4 wire snap connectors @ the front AC and rear AC units. It normally is a corrosion problem w/ the J11 connectors because they sit where there is moisture up inside of the AC units.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
MountainAir05
jannlanz wrote:
Thank you MountainAir05. Do you have the link to page 9 of the manual? Thanks!
will try this again.
http://www.dometic.com/b3056cd0-1a5b-4a15-8c1f-1d322d4ac84d.fodoc
jannlanz
MountainAir05
here is a manual that will help. On page # 9 I think, it shows a phone connector and wire.. that sends a signal from A/C #1 to #2, if not contact as in corrosion, then no control. To clean take a old tooth brush clean both ends. Spray with electrical contact clean and use di-electrical grease, Autozone has it.
jannlanz
Do you know how to remove the control panel? I pulled and tugged a bit, but it wouldn't just pop off so I didn't want to damage it. Thank you!!
jannlanz
We bought the RV new, so I'm sure we have the wiring diagram somewhere. Thank you so much for your help.
paulcardoza
Sounds like a probable bad/broken connection problem from the T-Stat for zone 2. Not a fun problem to diagnose. Do you have the wiring diagram for your coach and a multi-meter? Time to go hunting. 😞
jannlanz wrote:
Thank you for the information. I followed your instructions and FF did appear. I was able to set Zone 1, but now Zone 2 has disappeared completely from the panel. Previously, Zone 2 showed up but did not allow me to make a setting.
Thank you.
To Paul and Sandra: Zone 2 originally worked fine when we purchased the RV.
Paul & Sandra
Plymouth, MA
2014 Heartland Cyclone 4100 King
jannlanz
Thank you.
paulcardoza
Did it work previously and has stopped working?
jannlanz wrote:
Hello,
Paul & Sandra
Plymouth, MA
MountainAir05
Try this but first ensure that a breaker is not thrown.
2. System Reset
a. Turn the ON/OFF switch to the "OFF" position.
b. Simultaneously depress and hold the MODE
and ZONE push-buttons while turning the ON/
OFF switch to "ON". FF should appear in LCD
display until the mode and zone push-buttons
are released.
post back
