Android Tablet Question
mr__ed
Recently, my iPad was stolen and I purchased a new RCA Viking Pro android tablet, although I certainly prefer the iPad. My question has to do with using a stylus to highlight sentences on the screen. I find that when I attempt to move the stylus along the sentence in order to highlight it, the page tries to turn, so it's impossible to highlight anything. Is there any way to temporarily lock the page on the screen to allow highlighting? If I can't get it to work, I may just need to spring for a new iPad, although I do like the android tablet, otherwise. Thanks in advance for your assistance. Ed
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
12 REPLIES 12
MrWizard
Moderator
Moderator
glad you found the working solution
its just a matter of adapting to the new OS
I can explain it to you.
1997 F53 Bounder 36s
mr__ed
I just discovered something else today. If I use my finger tip in place of the stylus, I can successfully highlight entire sentences, very similar to my iPad. I'm happy with that, as I was almost on the verge of investing in a new iPad.
mr__ed
Thank you, Mr. Wizard. I'll try applying your suggestions.
MrWizard
Moderator
Moderator
its NOT about pressing hard or light
its about 'touch TIME', it is a different OS
its no harder to use, once you get used to it
touch any word for a second or two
then adjust the highlight section for what you want and choose copy delete etc..
you are used to doing touch and swipe using the apple OS
with android .. touch an swipe, with out waiting for the highlight is turn page/slide screen
same gesture different response
you have too change (get used too) to using the android gestures NOT the apple gestures you are used too doing
wa8yxm
About what I paid for mine. But as I said on my Android phone I press on the first word and it will highlight. Sometimes it grabs and entire sentence. Then I adjust the "commas" to what I want. Just like you want to.
mr__ed
wa8yxm wrote:
I have that tablet but don't use it much. Try this. Long press and the word you press on will highlight with a couple of comma shaped things at either end. Drag one of them to get the rest of the sentence.
I just wish highlighting was as easy as on the iPad. I could press fairly hard and the page wouldn't try to turn. I want to be able to run my stylus along an entire sentence and cause it to highlight without highlighting individual words.
BTW, my android tablet is an RCA Viking Pro, which is otherwise a pretty decent device for the money (I paid around $80 at Walmart).
wa8yxm
stickdog
mr. ed wrote:
Thanks for your reply, stickdog. Keep in mind I'm using an android tablet, not a phone. Swiping down from the top of the screen only reveals some notifications, nothing about locking the screen.
Mr Ed, my phone and my tablet are both Android and the icon s are the same on both and can be accessed from the front top of either device.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
sempka
on tablet I get 2 markers when I want to copy I find that I need to use the bottom tip of the marker to highlight.
2000 Holiday Rambler Admiral
mr__ed
I just found that if I use the stylus with a lighter touch, the highlighting works. However, the tendency is still there to turn the page. So, if I can find a way to lock the page so it doesn't turn, it would be a plus.
mr__ed
stickdog
Don't know your brand but on both my Moto4 and my Samsung Galaxy tab I can lock the screen. Just pull down the drop screen and the icon for screen lock is there.
FULLTIME SINCE 2010
17 DRV MS 36rssb3
John
