What mapping software
austinjenna
What mapping software do you folks use? I like to plan out my route and have it stay exactly like I planned it without it trying to reroute me, like the old Microsoft trips and streets days.
In google maps even when I create a custom map in google-my maps and send it to my phone, it will still show alternate routes or try to redirect me. I just want it to stick to the route I have planned out and curious as to what others use.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
25 REPLIES 25
Alan_Hepburn
The biggest issue I have with Streets & Trips is that I can'r get it to run on my laptop with a linux operating system. There are only 3 programs I use that won't run in Windows, so I have to keep an old laptop to run them - everything else runs on linux...
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
wxtoad
TechWriter wrote:
DFord wrote:
TechWriter wrote:
Tom_M wrote:
I also use Streets & Trips 2013. Roads haven't changed much since 2013.
Seriously?
I use RV Trip Wizard for trip planning & a Garmin 760 for day-to-day navigation.
As one that also still likes and uses S&T 2013, I can attest to the fact that the distance between destinations hasn't changed since it came out and the general routes still work fine for my planning needs.
You sure must not travel much. Still using Windows 98? ๐Ÿ˜‰
BTW, RVTripWizard costs $39/year. Hardly a deal breaker.
I'm still using S&T 13 - have no issues with it and it gets me where I want to go. We're pretty much two-laners, so a missing new on-ramp to an interstate is not a big deal. It's easy to trip-plan on and it runs on an old XP laptop that sits on our doghouse - nice big screen. Hooks to GPS puck on dash.
2005 Lazy Daze 26.5 Rear Bath
NE13
TechWriter
DFord wrote:
TechWriter wrote:
Seriously?
www.rvSeniorMoments.com
DISH TV for RVs
RLS7201
Still use Street Atlas USA. Love the big screen and the ability to zoom with the scroll of the mouse. POIs, from the POI Factory, are better on a Garmin.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
bighatnohorse
fj12ryder wrote:
whjco wrote:
I've used Garmin Basecamp, a free program that can be downloaded from Garmin's web site. I lay out our routes, then upload them to our Garmin GPS which then navigates us.
I don't believe you get detailed maps unless you've got the full maps downloaded, as in purchased.
As I understand it:
You get free and updated lifetime maps when you buy a new Garmin.
BUT, you have to keep updating the Garmin and if you fall behind on the updates (like if you fail to update for a year or so) then you loose the updating service.
Purchase for non-north america maps is required.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
โ€œThe best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
fj12ryder
Howard and Peggy
"Don't Panic"
DFord
TechWriter wrote:
Seriously?
As one that also still likes and uses S&T 2013, I can attest to the fact that the distance between destinations hasn't changed since it came out and the general routes still work fine for my planning needs. There's no subscription fees to worry about either. And yes, I'm as serious as a heart attack. To each his own. I'm very happy you've found a solution to your needs and I won't question why.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
TechWriter
Seriously?
DISH TV for RVs
whjco
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
APT
Google Maps/Waze - Can't beat the real time, crowd sources traffic that avoids slowdowns. If you want it to force an alternative route, pick some stops/waypoints/destinations along that path you want.
2017 Subaru Outback 3.6R
DFord
If I run up on a traffic jam, I'll never again listen to the phone/GPS when it tells me it's found an alternate route to avoid the jam. I did that once but the problem is a thousand other people did the same thing. The roads it directed me to kept getting smaller and smaller with more and more congestion. About an hour later, when I finally got back to the Interstate, the jam had long been cleared and traffic was moving at normal speed. Like I said, never again! I'll pull over if it's that bad and grab a nap or a sandwich (maybe both!).
Don Ford
philh
Waze app on the phone supplemented by an older Garmin GPS.
When they disagree, I'll have my wife open INRIX App on my phone to determine why they disagree. It is often that one is picking up a traffic situation before the other one. Sometime they just calculate routing differently. Generally, I know my routing ahead of time by using Google maps on my computer.
Funny story on a bad traffic situation caused by a multi car pileup. I wasn't towing at the time. Both GPS and Waze told me to get off at an exit that made zero sense... so i did. Ran into an epic traffic jam of everybody else getting off at the same exit. Stuck behind this over size load. So, I continued to reroute using the soft stuff between the ears now. Get back to the original reroute, and turned onto the road right in front of the over size load, literally gained nothing. Get back on the original route, right in front of a highly decorated and colorful semi, that stayed on the original route. It was eye opening... but I was a lot less frustrated ๐Ÿ™‚
vermilye
A Garmin GPS with updated maps, & paper.
austinjenna
I should have also mentioned I dont use a GPS, only the phone. I also want this for out on the bike so cant have a tablet or laptop for it. I miss the old S&T!
Reese 16K
