Back up camera system
uksheila
I have just upgraded from a 1999 Class B Pleasure Way (it's for sale if anyone is interested!)to a 2002 Coachmen Catalina Sport. It's only 2 ft. longer, but wider and taller and I really need help with parking and reversing. I thought a back up camera would help. I found this one:
7" COLOR REAR VIEW BACKUP CAMERA SYSTEM SAFETY CAR PICKUP TRUCK RV LICENSE FRAME 180ยฐ CCD CAMERA + 2 CHAN + INFRARED NIGHT VISION
on EBay for $230. The camera is in the license plate. Any advice or recommendations would be really appreciated.
Sheila
My '99 Pleasure Way and traveling cockerpoo companion, Waggie Thatcher.
4 REPLIES 4
falconman
I would get the type of camera that mounts higher up on the back. It will give you a better overall view.
RJsfishin
deleted
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
1492
Moderator
Moderator
Moved from Forum Technical Support
Dakota98
Appears to be a decent setup. Read all the specs. & options on it. It comes with one camera, but can be expanded to two, for extra $. Several other camera mounts are also available, aside from the license plate frame mount. Instructions indicate you can hot wire it to the ignition system or the reverse backup light circuit. Another option to that, is to connect to your headlight system, the camera would be on when the headlights are on only, rather than the ignition system method that has the camera on constantly, which I deam unnecessary & can still be used during daylight hours if you wish, like seeing behind the rig driving down the highway.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
