Just go into the receiver setup menu and go to Signal Strength and then Signal Meter. Once there, turn on the Carryout and and wait. After a few minutes you should see a signal strength in the 80 range and it will remain there. Assuming that's the case, you have it all hooked up correctly. Just be sure to set the antenna type first as described in the owners manual before starting the search.
Can't we all just get along?
