โJan-26-2014 08:46 PM
โFeb-02-2014 06:00 PM
โJan-30-2014 07:49 PM
Dutch_12078 wrote:Bumpyroad wrote:jhilley wrote:
You may need additional cables for Dishnetwork depending on the package you purchase. They use the same RG6 cable, but may require more of them.
yep, I am confused. my installer said that, the cable was bidirectional in that the signal from dish to receiver came in that wire and went back out to join up to the second receiver?
bumpy
All satellite, cable, Ethernet, telephone, and even fiber optic, cables are natively "bi-directional" barring the use of any blocking devices on the line. RG6 is the industry standard for satellite installations, although higher end installations, such as the Dish Hopper receiver, may require premium RG6 that's been rated for 3kHz use, versus the more common 2kHz RG6.
โJan-29-2014 12:15 PM
Bumpyroad wrote:TechWriter wrote:
Your house install with "backfeed" probably looks something like this (PDF).
If you moved your 625 to an RV, this backfeed setup wouldn't be necessary if you only have two TVs.
yep, sorta looks like it. is that single wire to the 625 a standard 6?
bumpy
โJan-29-2014 10:11 AM
bumpy
โJan-29-2014 10:10 AM
โJan-29-2014 09:15 AM
Most DISH RV systems involve a single RG6 coax from a dish (portable or roof) and that single coax is connected to a single receiver. Some receivers have RF outputs that enable you to distribute the signal to other RV TVs using the coach's cabling.
There are, of course, more complicated setups depending on what you want.
Here are DISH RV TV examples.
couldn't find my 625 with 2 TVs on that link. my setup has one (1) wire RG6 coming into the house to the 625 receiver from a connector on the outside. my TV 1 is hooked up to the 625. a RG6 wire runs from that connector on the outside of the house up to the second TV. there is only the one feed wire to the 625, so I "assume" it is as the installer said, the signal (by magic) goes both way thru that one wire??????????????
bumpy
โJan-27-2014 01:33 PM
โJan-27-2014 11:03 AM
bumpy
โJan-27-2014 08:31 AM
โJan-27-2014 08:09 AM
โJan-27-2014 07:24 AM
Bumpyroad wrote:
the only time new cables might have to be run is if you put in a dual receiver such as 625 that my installer said takes a special cable so signals can be bi directional or some such.
bumpy
โJan-27-2014 06:25 AM
โJan-27-2014 02:47 AM
โJan-27-2014 01:32 AM
INDIAN CREEKER wrote:As long as RG6 coax is being used in your trailer, I can't see that there should be any problem. Having said that, I am not a satellite "expert", I just use it.๐
We have a Park trailer, Salem Villa. It was prewired at factory for Satellite. We had Direct TV hook us up and had no problems using the factory hookups. Now we are changing to Dish Network. Can I expect the same easy hookup with Dish Network?
Or can I expect the installer to want to start drilling new holes for ho reason at all?
Thanks,
Dave
Walter & Garland - Camp Canine caretakers
Miss Inga (aka "Shorty") - 10 y.o. old GSD.
Gen. Gretchen - Joined Rainbow Div., June 27, 2017 at age 13
Gen. Missy - Joined Rainbow Div., June 11,2006 at age 12
2018 Montana HC305RL 5th wheel
2018 Silverado HD 6.0L
