โDec-14-2016 04:57 PM
โDec-18-2016 07:23 PM
Twain wrote:theoldwizard1 wrote:Dutch_12078 wrote:
That antenna is for receiving stations broadcasting on UHF channels only. It will not receive the several hundred stations broadcasting on VHF channels unless they're next door to you.
Several hundred ? My understanding is most stations changed to UHF when digital rolled in. Remember, "channel number" now has nothing to do with frequency.
Yes, UHF is more "line of sight" but the benefit for the consumer is a much smaller antenna.
I would just "write off" the VHF stations and get a taller mast instead of a larger reflector style antenna.
Most old VHF stations had to go to UHF for an open freq to broadcast the new digital signals. Then a few years ago when the FCC made them stuff off the analog transmissions, many stations came back down to VHF (mainly channels 7-13) with their digital transmissions. Better range. In the Tampa and Orlando markets, 3 of the 4 major networks are VHF.
โDec-18-2016 07:01 PM
โDec-16-2016 11:32 PM
Bumpyroad wrote:silly me..SCVJeff wrote:what and confuse rumor with fact?
. Check it out.
bumpy
โDec-16-2016 02:22 AM
SCVJeff wrote:
. Check it out.
โDec-16-2016 12:12 AM
theoldwizard1 wrote:You heard wrong and it is a common misconception that VHF is dead. That is totally untrue, and as I said above: once this latest auction is over, VHF will be as loaded or more than it was in the past. If you cast off VHF now, you are going to be in for a big suprise in a few years when it's even more active than it is now.Dutch_12078 wrote:
โDec-15-2016 03:35 PM
theoldwizard1 wrote:There are more than 1700 full power TV stations in the U.S. About 25 percent of these stations are presently broadcasting on the VHF band, so DO NOT just "write off" VHF.
โDec-15-2016 02:12 PM
โDec-15-2016 01:43 PM
Horizon170 wrote:
I wonder how this compares to the Batwing?
https://www.antennasdirect.com/store/clearstream-4-ultra-long-range-outdoor-dtv-antenna.html
EDIT---How do I make this a HOT LINK?
โDec-15-2016 11:53 AM
Fizz wrote:
I tried one of these and the Batwing was better.
โDec-15-2016 11:52 AM
โDec-15-2016 11:44 AM
โDec-15-2016 11:01 AM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
โDec-15-2016 08:59 AM
โDec-15-2016 07:02 AM
