Dish Satellite 129
RLS7201
Any one else having trouble acquiring satellite 129?
I have a Winegard Pathway X1.
I was unable to see satellite 129 while at the Indio, CA fair grounds and only get a signal strength of 7 on 129 at Quartzsite.
And NO, there was/is nothing blocking the dish's view.
Thanks
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
8 REPLIES 8
RLS7201
Thanks for all the responses. The X1 is powered through the coax and is working and the signal strength is good on satellites 110 & 119, so I would think the coax and connections are good. No obstructions are present. I'll see what Winegard has to say.
Richard
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
KCFDCapt
Could be a bad LNB on the unit.
donn0128
I would gueas bad coax. At least its worth a try on the cheap. Could also be a bad connector. Heck, a bad power cable could be causing the OPs issues.
Big_Katuna
rk911 wrote:
Big Katuna wrote:
rk911 wrote:
how. are you pointing the dish? suggest youbtry the 'Dish For My RV' app. it uses the phone's. camera to show you where the sats are.
The Pathway is an autoseek dome. You donโ€™t point it. You set it on the ground and click a box on your menu..
I have intermittent issues getting a signal. Maybe try a better cable or clean your connections.
doesn't an autoseek dome require one side to be pointed in a specific direction before activating? maybe the dome is not set correctly? seems to me if it were a bad cable there'd be a problem with all of the dish birds.
They suggest pointing the cable connections north but it doesnโ€™t seem to make a difference.
Iโ€™m assuming the sats have differing signal strengths so one could be below threshold due to atmospheric differences.
My Kharma ran over my Dogma.
Bill_Satellite
Not necessary with a Winegard dome.
Can't we all just get along?
rk911
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Big_Katuna
rk911
Rich
'46 Willys CJ2A
'10 Jeep Liberty KK
