โMar-17-2017 09:39 AM
โMar-19-2017 04:05 PM
โMar-19-2017 03:36 PM
HTElectrical wrote:Yes. That's the same one on my Slimline. I can't vouch for its use with any other dish. The Slim's do get heavy and bulky to cart around, have to admit that.
Is this the correct LNB?
โMar-19-2017 03:24 PM
โMar-19-2017 12:47 PM
HTElectrical wrote:I shoot the 101 to > 90, usually 93. The others will be in the 70+ range, highest around 85. That works.
what kind of signal strength #'s are you getting on the 3 sats?
โMar-19-2017 12:32 PM
โMar-19-2017 12:15 PM
โMar-19-2017 12:02 PM
Ivylog wrote:
Yes a SL3 will bolt on the dish above. There may be a notch on the SL3 that requires spreading the U shaped mounting apart slightly.
โMar-19-2017 12:01 PM
Bigbird65 wrote:
I previously bought a Slimline system system that just didn't work right. The signal strengths were way down. Lots of trial and error testing including replacing the LNB. Others who bought this system complained about the exact same thing. Nothing helped. I finally determined that the shape of the reflector or arm geometry was wrong. I bought the current system and couldn't be happier. It is a lot more than just changing out the reflector mechanically. The LNB, arm, and mounting assembly must be exactly matched to the reflector or it just won't work. Trust what I am saying. Been there, done that. Best of luck to you HTElectrical.
โMar-19-2017 06:58 AM
โMar-19-2017 05:54 AM
โMar-18-2017 08:07 PM
โMar-18-2017 10:58 AM
โMar-18-2017 09:20 AM
โMar-18-2017 05:58 AM
